Actually it's been crossing my mind tonight....but i won't go into that. Will i Cassi? :D
Member you'll b disowned by me and Amaru, tisk tisk *shakes head* im so.. nope i have to go *runs off shaking head in shock*
marty: i have no idea its some lil mouse thing my friend put it on lol
