so am i Beau its all good. Gus/Beau if you guys do need a lift to the cotter for chirstmas party let me know as i wll have to head that way anyways.
ps Sin you up for this or what, pm me with address and ill pick you up mate
Edited by race_snooze
  • 1 month later...
i figured this was the place to post it plus no one had in a while but i decided to change my spark plugs today... note it took alot longer than i thought it would which was annoying...
anyways pulled the plugs out and they actually didnt look to bad... still i replaced them but have since done some research and found them to be a double platinum plugs first i have ever heard but they seemed to go alright for me :P... oh also my coils look like brand new as well which makes me happy no sign of fraying of cracking at all WOOT :)
http://www.autolite.com/products/doublePlatinum.php
