doesnt work :(
no more youtube for me :D
don`t work for me
work hasn`t been the same since they canned youtube it hard to make it through a shift without seeing a fat person trying to get into a boat or an american playing with fireworks
I occasionally speak with this chick over the phone at work.. for work purposes, and she sounds hot.. but I've learnt from the past that hot sounding chicks.. are usually "voluptuous".
Hahahaha, yeh I made that mistake when I was 17, voluptuous to say the least. Nice person and all.
At ATO, they've realised that you can look at p0rn images thru the google image search. I really shoudl have kept my mouth shut. :laugh:
why oh why would you want to browse porn at work?
i mean, stuffing around on youtube to pass time is one thing, but gettin your rocks off is another.
hey all just wondering if anyone could help me with contacting bullet32, im looking at putting a 25 in my r32 and i want to have a chat to him about cost/procedure but he hasnt signed in on SAU since january 1st
any help would be very appreciated
thanks
-simon
Edited by MANG
Oh Shit yes!
Except when your talking to chicks from sales, they generally have to be hot to get hired.
But there are a few nasty ones that somehow sneak in there to ruin it. >_<
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
