i found a giant gobstopper in my old car when i was cleaning it to sell it, last time i remember having one of those in the car was right after i bought the car, it couldnt have been in there that long though, id hope :S and i found my ex's spare house keys that id argued with her about, swearing that i didnt have them haha oops.
Edited by MANG
When i took the seat out of my old skyline i found some sauce (minus packaging) and 1 condom (also minus packaging...) and about $10 in coins.
lol. sounds exactly like michael. filthy boy that one
EEEEWWWWWW X 2
When I pulled the boot lining out of mine I found about 20 glow sticks fallen down inside one of the rear guards. The car must've belonged to some hardcore ravers in its previous life.
rofl, keep looking might find something else
I was just looking for a set of rims for the new Forester, trying to get a set of TE37's, when looking i came across these and creamed my pants... I think they would be the ultimate wheel for an GTR... SOMEONE GET THEM
I will contribute $5 of my own money towards someone getting these :)
you like your volks dont you leigh?
It is true :( if i get lucky i will be the proud owner of a new set in a little while. won't say what sort yet as there is a decent chance someone will out bid me... speaking of volks i should look to sell my GT-C's
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
