I must admit that is a pretty funny comic strip...
I only dont like "guitar hero" because I suck at it, which is really wierd because I have been playing REAL guitar for over 15 years... Just shows that the game is nothing like the real thing. :)
Yeah I failed miserably at playing guiter in school (carny hands), but I am quite the weapon it seems at Guitar Hero :laugh:
PS: Morning ACT!
Morning Steven :cheers:
Don't stop taking the p!ss out of fra... oops I mean Mick though :)
ok... I'll splain it... in crayon...
When you were up here, I forgot your name and thought it was Frank (or Frink) cause that's the only name I remember from that list in your sig...
Either way, you're still coming ice skating next time...
I played real guitar for about 3 years back in highschool but never really got that great. Guitar hero though... All 3 games combined theres only about 15 songs i havent 5 starred yet in expert.
I play it way too much haha
Skylvia - Try JB and EB and get them to call around to all the other stores in Canberra, thats how i got guitar hero 1
OH OK, now I remember... You smart ass.
I dont think I like the idea of ice skating... Moving fast on thin blades on hard packed ice sounds like it would end badly for me. :)
HA! knew you would remember :laugh:
Oh it's fine... if that blonde chick can do it, surely you can!
It's pretty easily actually, like rollerblading but you can stop... I'll find some hottie to help you out :cheers:
I dont think I like the idea of ice skating... Moving fast on thin blades on hard packed ice sounds like it would end badly for me. :rofl:
c'mon you live your life skating on thin ice :D
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
