Shell - WTF with my Avatar :(
On my lappy n desktop I have an R35 dash and steering wheel. On others its showing a profile of my Supra side on. Havent had that up for a month or more...
Help needed.
;) - Give a boy a gun and badge and watch the birth of an armed meglamaniac who works as a revenue collector on the side.
C**nt's dont desrve the respect I tried to instill in my kids that Police officers were here to help (protect and serve). If you want justice you need to dish it out yourself.
anyway....
Hi Shell - had the same prob. you need to go past the arrivals/departures at the Airport and take the first left, left and left. It's not easy to find.
oh good to hear... so I'm not a total tard ;)
I gave up and made them put it on a flight this morning instead
ps. your avatar is the interior of a R35
lol @ Ex!$t3nZ and his random pics... what's it look like now? an R31 door? ;)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
