Got it for Free, had CRAZY colours all stripey on the screen even with no antenna plugged in, couldn't even get a picture, would cost $100 just for a Pro to look at it & yes it was heavy as all Buggery. Extremely unfortunate. :(
you can pick up decent plasma tv's in the $400 mark ish for like 45-50" size if you shop around
40k seems way too high.. i dunno something rubs me the wrong way. esp since its a v spec
Defs. I also has a feeling something not Kosher there. doesn't feel right hey!
Although not about spending $40k on a GTR rebuild, boltons, upgrades etc... I'm sure few of us on here could walk through some receipts.
Getting to 350awkws is not just new turbos and/or stock rebuild, It can be but it wont see the year out. Then if you want to drive a good car theres more to be done.
And if you want it to last you go all the way through it thoroughly.
You would have spent over $20k.
Have you done New brakes, Extended Sump, High Volume oil pump, Oil cooler and relocation kit, Quality Steering and Suspension, Interior/Exterior titbits :)
So your right. The devil is in the detail he hasn't provided.
Sorry dude for you in the poo :/ . cant rag on peeps in FS section no more.
Ps: oh and my FS in his FS has been deleted too - lol
Chrome? Is that a drugo's term :P
Fox and Chrome can go eat a dick!
Speshally seeing I'm old and started on IE so will stick with it. More intuitive.
IE8 solved alot of the response time issues and 9 has capatalised further :thumbsup:
Mind you I prefer Nokia phones over I-phones and Windows OS rather than bad apple's
mayhaps users of the other browsers just dont like secure browsers :rofl2:
In my experience, Internet Explorer is the least responsive and most resource hungry browser of all time. Runs like an absolute heap of shit anywhere I've used it ---> install Chrome ---> everything works like a dream.
This. Also Itunes also chuggs through PC usage like the whore it is. In saying that Chrome does as well. but chrome is soooo smooth
Quick question guise...
I picked the car up from the shop after getting some steering components installed and they said that I needed to keep an eye on the clutch as 'it was catching a bit high' or something along those lines. I just smiled and nodded..
Wat does that mean? I've never heard that before...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
