bahaha noooo from dancing with teh ladies all night Saturday ;)
then 9km on the cross trainer early Sunday morning (I'm f**king horrid with cardio lol)
Yeah I feel the same about cardio...(km's...I would have a heart attack!
I get my cardio mixed in with my MMA training. I can not just run around an oval or on a treadmill etc. Way too monotonous!!!
When you're as out of it as I usually am the time of morning I'll do cardio, it's not that bad :P but if it were after midday when my mind has finally booted up properly, it ain't happening. Hours of trance podcasts help a lot too!
Me no train in the mornings. I am not a morning person at all. LOL
Only on weekends for me. I struggle on weekdays thanks to farked sleeping pattern (if you could even call it that, lol). At least on a weekend nothing forces you to get up until your mind is awake enough to care lol.
I am not awake until three hits of caffeine!!
I love cardio - and fitness training ! I cannot think anything better to do of a morning then to get on a tradmil and run for 35kms or even run around the lake.
Anyone who has seen me knows I'm telling the truth :P
I'll hit the pre-trainer before gym in the morning on a weekend. That's somewhere around 250mg of caffeine, or just over what you'd be getting from 3 shots of espresso. Plus is has other shit in it that can't be good for you LOL
Ah, but do you even lift? :P
I get my "lift" workout every time I need to chuck a piss m8.
Wont be dancing when you get the invoice Mik - sort of like Dafuq :huh:
Espesh as your a DIY and don't normally get the bill
Its ok, ive been saving for ages as i havent got it there as soon as id liked.
And sometimes you just gotta pay the pros to get it all right.
Being a tradesman i have no problem with that. Its only fair.
And after reading about them here and there i have confidence they will do a good job.
Watching my car being towed i noticed the left side of its face droops ever so slightly.
Edited by D.I.Y. Mik
Hahaha! i was thinking the same thing.
Its already had some plastic surgery.
I think it had more than a stroke........ well shes been in the wars thats for sure. :pirate:
Actually stressing a bit, i hope i did all the right things with the right bits, and i didnt give them a headache to fix.
Its because of all the work and money and work... back breaking bloody work doing the shed so i could do the car.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
