I believe how virus' attack is that you could have the virus 3 months piror to being sick, but your immune system keeps attacking at it fighting it off, but when your immune system drops (whether it be from tempture or reduction of vitamins) the virus will attack the body and get through the immune system. This is what I was told - no real source bar Google to back it up.
The keep left thing has nothing to do with the signs, it's to do with the speed limit. 80km/h and under you can sit in whichever lane you want. Over 80km/h and you must keep left.
If this is true, then I'm going to continue high-beaming the absolute f**k out of anyone doing this shit on the highway.
I'll still do it in 80kph zones. Not like these muppets would have half a clue on the correct laws anyway.
What if the sign said Keep left unless overtaking in a 60km/h zone?!?! :O!
It's true :P I thought it was common knowledge - don't they teach people basic rules in drivers tests anymore? lol
I keep left in 80km/h zones.... or even less if it's practical to do so. Some things are just common courtesy!
personally I don't consciously make sure I'm in the left hand lane, but that's pretty well entirely because I AM the faster car 99% of the time. However if I notice someone approaching I'll make an effort to get out of their way anyway.
Common courtesy is spot on, which is why I get the shits so badly. It's not like they're just breaking the rules - they're being f**king rude and inconsiderate!
Find me one in a 60km/h zone.
The signs are just reinforcing the road rules... which is why they are in 90 zones or above.
I'm on it ! > :( Detective Jeremy on the case !
Anyone have photoshop skills I can borrow? :D
Edited by RosieR34
I honestly have no idea why people are in such a rush anyway. It's not like you are going to save world peace or anything at your job. Just chill seriously lol. All these pubic servants have the most important job in the world and they are more important than ANYONE else.
A little off topic, im putting a 650 engine in my 250 mwhahaha
It's how we role ;)
i knew you where a pubic servant
Also i have a hyosung gt250r. The shell and everything is the same from a 250 to a 650. All i have to change is the engine and if i want too the rear tyre haha. Don't know if i want to bother yet. I might just get a 70's mini and fk the bike off, save up and get a ducati
Edited by Anfanee
rear hub 650 or it will break
i always wanted to do a 500 single 2 stroke in a 250 sportbike.
not easy to make legal though, most 500 2 strokes are not adr complied, except the cr 500e which is rare and expensive.
big bore two strokes :banana:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
