I believe how virus' attack is that you could have the virus 3 months piror to being sick, but your immune system keeps attacking at it fighting it off, but when your immune system drops (whether it be from tempture or reduction of vitamins) the virus will attack the body and get through the immune system. This is what I was told - no real source bar Google to back it up.
The keep left thing has nothing to do with the signs, it's to do with the speed limit. 80km/h and under you can sit in whichever lane you want. Over 80km/h and you must keep left.
If this is true, then I'm going to continue high-beaming the absolute f**k out of anyone doing this shit on the highway.
I'll still do it in 80kph zones. Not like these muppets would have half a clue on the correct laws anyway.
What if the sign said Keep left unless overtaking in a 60km/h zone?!?! :O!
It's true :P I thought it was common knowledge - don't they teach people basic rules in drivers tests anymore? lol
I keep left in 80km/h zones.... or even less if it's practical to do so. Some things are just common courtesy!
personally I don't consciously make sure I'm in the left hand lane, but that's pretty well entirely because I AM the faster car 99% of the time. However if I notice someone approaching I'll make an effort to get out of their way anyway.
Common courtesy is spot on, which is why I get the shits so badly. It's not like they're just breaking the rules - they're being f**king rude and inconsiderate!
Find me one in a 60km/h zone.
The signs are just reinforcing the road rules... which is why they are in 90 zones or above.
I'm on it ! > :( Detective Jeremy on the case !
Anyone have photoshop skills I can borrow? :D
Edited by RosieR34
I honestly have no idea why people are in such a rush anyway. It's not like you are going to save world peace or anything at your job. Just chill seriously lol. All these pubic servants have the most important job in the world and they are more important than ANYONE else.
A little off topic, im putting a 650 engine in my 250 mwhahaha
It's how we role ;)
i knew you where a pubic servant
Also i have a hyosung gt250r. The shell and everything is the same from a 250 to a 650. All i have to change is the engine and if i want too the rear tyre haha. Don't know if i want to bother yet. I might just get a 70's mini and fk the bike off, save up and get a ducati
Edited by Anfanee
rear hub 650 or it will break
i always wanted to do a 500 single 2 stroke in a 250 sportbike.
not easy to make legal though, most 500 2 strokes are not adr complied, except the cr 500e which is rare and expensive.
big bore two strokes :banana:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
