A quick look under the car can be dangerous.
http://www.canberratimes.com.au/act-news/man-70-dies-under-car-in-chapman-20140622-zsi65.html
A pity someone died to remind us to be safe. :/
Chassis stands on level concrete at the minimum please.
I'm about to ask on FB but I might as well ask here too.... new house has a space for a fridge and both Tars and I have big-arse fridges that don't fit. Anyone want want to swap an upside down Fisher & Paykel for something slightly smaller? I think it's a 540lt or whatever.
