lagging turbo...
Hey guys hoping someone can help me out here, i got an R33 '95 Skyline it is A1 externally/internally no body damage and the mechanic that just changed my clutch said that it is one of the cleanest his seen but...
When I m givin it some stick and it get's to 5000rpm it just completely dies in the ass until about 6000rpm (i have only tried to push it past this a couple of times and it picks up like crazy again! What would be causing this lag between 5-6000rpm? It mainly only happens in 4th and 5th gear... I mean my mates VP clubsport can beat me atm :)
Also I m idling very low like 400-500rpm and usually after it has been running 4 a while it'll stall when i come to a stop... I have read of this happening before an i think it was the air control valve near then plenum?...
Please help I want to beat my mates clubby! :)
https://www.sau.com.au/forums/topic/5457-lagging-turbo/
I use BP ultimate as advised by most of the people on this forum...
in regards to your quote "In 4th Gear and 5th would suggest to me that what happening is the typical R33 ECU pulling out timing" how would i go about rectifying that?
no i don't have a FMIC I m working on that
yeah it's the same in all weathers and my exhaust is i'm not sure what brand :Oops: but very big loud and shiny and sounds really sweet. (I really need to learn more about my car!!!) The exhaust is huge all the way through I know this after looking under it whilst it was on the hoist getting the clutch put in.
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-83225
happened b4 i got the clutch and the same now I think it deffinately needs a service and from reading a few threads in here i think i deffinately need a full service and maybe the spark plugs replaced...
I have to say though since getting the clutch replaced I have noticed a big difference in the cars performance.
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-83226
Guest MFX_R33
Sounds like yet another Skyline coil pack problem. You can check the coil packs by getting another one and then proceed to swap it one at a time and ckeck it, or even better if you know someone else with a Skyline swap all the coil packs from them and if it dead spot is gone you have found your problem.
Jeff.
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-83450
IJST8U are you from Central Coast NSW as in Gosford?
The coil packs are found under the cover on top of the engine. They are directly connected to the spark plugs. Remove the nice looking black cover from the top of the engine and they will be revealed.
Not hard at all even for non-mechanical people like me :)
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-83586
IJST8U
Ive had some similar probs with mine when i first got it.
Do you have a BOV? if youve got vent to atmosphere one, then that could be a prob causing the stalling. BOV's can cause little problems that might not even have you think about the valve itself!
do you have a bleed valve?? if so try turning your boost down.
it sounds like the stock ECU pulling timing to me. Mine did it when it was cold weather, like at night. It also did it just after i fitted a front mount intercooler. Apparently air was getting in from somewhere and confusing the ECU, causing power dropping off, then suddenly surging back on.
Lastly, have your throttle position sensor checked out.. I had some really weird idle probs which were cured by a slight adjustment.
Although im no expert at coil packs, i dont think it is those. For one your car is a 95. The fact that many hard driven 1989 32's are still firing fine shows their reliability, and i read that age is their main enemy. And you say it is worse in 4th/5th gear. To me this would indicate an air related prob -> =ECU is the cause. It also makes coil packs as the suspect even less likely.
Also you say that the power comes back on and pulls like crazy. So the packs are delivering voltage to your plugs fine. If it were the coil packs, then multiple packs would need to be faulty for the car to "die in the ass". One pack maybe, but the chance more than one has gone is next to nothing. (if im wrong let me know!)
Put it down to a faulty/confused ECU or an air leak. Thats most likely.
You didnt say whether youd taken the car to anyone? rock up at a performance centre and ask their opinion, easiest way to go
:) no expert myself, but have learnt a lot during my short time owning a line :burnout:
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-83888
Sounds like stock ECU commanded timing retard. Except it would be it in all gears not just 4th & 5th. Coil pack? I wouldn't have thought so? As it comes good from 6k onwards.
Does it flatspot in the same rev range every time? i.e. it's always ~5k it dies & ~6k it comes on strong again.
What mods have been carried out on the engine?
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-83918
IJST8U, are you running with the stock airbox? You wouldn't believe the problems I had with the stock airbox, and yes, one of them was running like buggery 5000rpm+. Try going for a quick squirt with the top of the air box off and see if it makes any difference.
Otherwise, its definantly the dreaded igntion retard problem, and only a S-AFC or other ecu is going to fix that.
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-84230
yeah sorry bout the late replies, i have nothing done to the engine really... no BOV looking at getting one soon but overall the car is just standard and clean I m looking at getting an S-AFC soon just need the funds...
I haven't takin it to anyone yet will soon once again just a cash issue.
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-84364
Happened to me too. The stock airbox or the blitz filter element I was running was restricting the airflow at high RPM and causes the engine to retard (ie: car would stop pulling till I changed gear). I fitted up a HKS super power filter and all is fine now. I run 0.8bar of boost with 1.1mm or 1.0mm gapped plugs and I havent experienced any misfires or flat spots.
Rob
https://www.sau.com.au/forums/topic/5457-lagging-turbo/#findComment-86629
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
