Sits in the drivers side air dam and looks like an oven element. Sort of curls around and is a pipe for something. Maybe brake fluid cooler?
I took a photo but I don't my cable to download the photo at the moment.
I want to attach my transmission cooler to it so I can fit my intercooler in the front.
https://www.sau.com.au/forums/topic/54626-whats-this-thing-r34-gtt/
Yep.
Very Very basic cooling system. Sometimes you will see them with a plastic jacket with lolts of fins on them. The fins obviously help cooling.
Commodores do the trasmission cooling in the same way.
Well, put it this way.
I wouldn't do it to my car.
Think of the transmission cooler when it is full of oil, probably weighs a couple of Kilos.
when think of the bumps you will encounter on way to day driving, and the effect that couple of Kilos will have on your transmission cooler lines.....
Not good.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
