The R33 GTS of Magic1 from these forums ran 511rwhp at PAS western salon today on Speedworks Dyno.
This car is an RB25 with Arias pistons GTR rods and 256/264 HKS cams using a GTR cooler and Wolf plugin ECU and a GT30 Garret turbo but still has stock injectors and intake manifold but Sard reg and 044 pump.
We tuned it to 20psi and 11-1 afrs running pump BP98 fuel.
Tristan also won Ovaboosts and SAUwa Dyno comps and featured hi in Genies dyno comp and yes he drives this car for work everyday.
I know the usual knockers will bag the results so maybe its time one of them came to WA and inspect some of our cars even taking them to the Dyno of their choice.
Never underestimate the mighty RB25!
https://www.sau.com.au/forums/topic/54904-r33-gts-511rwhp-stock-injectors/
  • Replies 196
Well done to Magic, sounds like a beast of a whale. I would have thought the stock injectors would have been maxed out ages ago. Its good to see someone making all this power with minimal mods, by the looks. What other work has the car had done to it? ported/polished ect? :D
I've got $50 that says it wasn't a DD dyno and wasn't on shootout mode 04, as for the stock injectors hahaha what was the fuel pressure and as the wolf batch fires them its not really fair comparing this HP figure to say what a Power FC could produce with stock injectors, sort of gives the young guys and newbies the wrong idea and they'll blow there engines trying to do the same thing .... talking about blowing engines I seem to notice a pattern of blown engines over there that are running bigger hp with stock injectors could this be a contributing factor maybe???
Congrats on the result:thumbsup:
Care to enlighten us how you are consistantly able to make that power out of std injectors?
Out of interest what cc are RB25 injectors? I guess based on cfm of air to make that hp and 11:1 A/F i suppose its possible to work out an approximate capacity of the injectors?
511rwhp... steve either your a genuis or wa dyno's are bit happy. On a dd dyno the most i made from the same set up you just mentioned using stock cams and forward facing stock plenum was 387rwhp. If this car has truly made that power, im expecting low 11s hi 10s @ 130mph. Unless its just a dyno car?
How ever the case, awesome result.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
