  • Replies 196
Hi Steve-SST,
I have an RB25 with ARIAS pistons, Linished, Shot Peened and Cryo Tempered Rods, HKS GT 3040, HKS topmount manifold, PFC, Tomei Poncams 256/9, 550cc Sards, Greddy/Trust Plenum, Ported Head Iski valves prings, Micks MC bar & plate cooler 100mm, E-Boost and Trust Type R W/G 45mm, Q45 Throttle Body, Q45 AFM, 90mm Fujitsubo Exhaust, 90mm dump & very hi flow cat.
Max I could get out of it was 330rwkw @ 21 PSI. (DD Dyno in shootout mode - do a search and you will find the dyno graph I posted)
Since my car is very similar spec to Pauls and Magics -
If I change from PFC to Wolf - am I gonna get 50 rwkw increase ???
Cheers !
/edit = PS I run 118 mph (18PSI) - but I am CRAP at drag racing :(
The post stands it did make 511 on Speedworks dyno and as Tristan said read the following posts and you will find out what it made in shootout.
Speedworks claim their dyno is the only one thats right i think our dyno is but you guys make up your own mind.
Hi Steve-SST,
 Cheers !
3040 rated at 500 at 1bar, cant see why a wolf and the right tuning it would not get 440rwhp. a bigger fuel pump might be needed along with a better head gasket
Just wondering, if injectors are run at or very close to 100% duty cycle, are the spray patterns adversly affected?? Also, I noted that BOOSTD mentioned that increasing the fuel pressure by higher than 10% screwed the spray patterns, but I dont see how this is appliciable if the standard reg would be boosting the rail pressure during boost situations anyway??
330kw = 442.5372hp!
Dunno how many times I have said this....
Forgot to add - HKS 1.6mm head gasket and Bosche 040 pump.
I want the 380rwkw you guys keep talking about with Garrett GT30s - ha ha
The only real difference is the Wolf - and I can't see how it can be done !
But hey - that's just my opinion
Time a Mod locked this thread and wait for the Drag slip but then there will be hidden NOS storys etc.
Get real will ya !!!
You and your chronies get great pleasure in trying to make yourselves look ahead of everyone else.
You are the one started this thread with a claim of 511rwhp knowing that it was a false reading, inviting everyone to scrutinize the result.
It turns out that the result is nothing out of ordinary and is replicated everywhere else, with the exception of difference in injector sizes. Big farken deal, next time you are in VIC, let me present you with a plaque carved out of an off-cut 0.5mm steel. If you try my earlier suggestion of cam gear modification i will upsize it to 1mm.
To finalise, why is there a 40 degree difference between the intake and ambient temperatures...? It was explained to me by a DD rep that, 40 deg. difference would add an 8% to the reading.
In short, move along fellas...
Emre, STFU, from the being steve and magic1 said that the reading will most likly be out as SPEEDWORKS (the dyno in which was uses @ PAS) reads higher.
WHY DOESNT EVERYONE get over themselfs? I ****ing sick and tied of people bitching just becuase YOU AND YOUR TUNER CANT make the power steve and sst can.
like steve said someone lock this thread, its got out of controll its kind of like a FLAME war between everyone not in W.A and the boys in WA,
You have absolutely no idea about anything, so i susgest you STFU.
Its got nothing to do with wa versus other states, its the inability for ppl to answer questions.
Tristans car will do the times, just give the guy a break. he didnt start this thread btw.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
