track/drift day saturday January 15th $150bux
well i have been at oran park to watch a race once (like 4 years ago) and the corner coming onto the striaght has a well used wall that has stuck in my mind..
btw 4doorGTR im the guy from wsid with the red gtst you said hi when i turned up so hi its me :D
  • Replies 372
for ****'s sake
me and mate been workin on our 31s sionce morning to get em ready
bled brakes etc
we just finished chucking new nultec bushes in upper and lower controilk arms for mine
then go to change the unijoint coz mine is cactus
and what do ya know
pepsauto sold me the wrong ****ing one
after i made em check 3 times!!!
its bigger than the noraml r31 uni (rear)
****ing hell
no go on the car
All ready to go.
If anyone has a decent trolly jack it would be good. Mine is only a cheapo, but I have the compressor, rattle gun and tyre inflator ready.
Cya in the morning.....one more sleep:wassup:
Pete,
Thank you for a AWSOME day's driving.
It was well managed and pleanty of track time for all.
I missed saying goodby as you were sending more tyres to the smoke gods, but I wanted to T H A N K S
Mal
Owwch!  So how did these crashes occur?
There were two incidents..
1. The first stack was the wrx. It was in his first run of the day in the first "track session". He hit the wall coming in onto the straight. Check out the front drivers side wheel and the scrapes all the way down the side. I noticed he also smashed the side windows.... nasty!!!
2. The second crash was between two cars in one of the "drift sessions". Basically the ass end of one car ended up in the front of another. It was on turn 2 on the south circuit. I guess thats drifting...
Bring on the next day....
I didn't have such a great day ,,,but hey I got to catch up with all you drop kicks which made my pain easier. It pleased me greatly to see Dan get on pace so quickly. 1st session buddy you were on it. I was also pleased to see the counrty boy hold out that crapy Mini,,,well done mate.
All in All I think SAU had a great day.
Thank Fatz.
P.S. I'M PISSED
Neil.
Pete,
Mal
Wanted to say thanks for a great day also! and mall thanks for letting me use your compressor!!!
also why the blanked out number plates? just in case big brother was watching????
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
