Anyone know where i can get these doylie seat covers???
http://www.prestigemotorsport.com.au/au/st...sp?StockID=2681
I have been importing doylie seat covers for some years now, and stock models from all the major aftermarket manufacturers (turst, KHS, Grdeey and Biltz). I only get the best ones in and this is reflected in my priceing structure. If you were born in March, October, November or June the covers start from $800 USD each, all other months start from $850 each. PM me with your orders.
Richard
Richard
Hahahaha lol... funny sh*t :)
Richard
w00t!! heres to being born in June :looney:
Due to the amazing response by PM I'm going to run a group buy on these. This will drop the price per set to $727.27 (plus GST) for those born in the months listed above, all others will need to pay $772.73 (plust GST) both amounts are USD. Yes, these include front and rear seats and will put your full-sick-o-meter (a fatz invention) off the scale.
Richard
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
