  • Replies 85
whos the dude on here who just got a GTRS tuned on a 33? he got i think just over 250rwkw on 1bar, so i think there should definitly be more in it with more boost, which would put it quite ahead of the 2530- which is a good solid street turbo, which can only be faulted for running out of a bit of puff at the very top end.
For the price of the GTRS's at the moment they are a steal.
There seems to be lots of support for the 30xx series, looking at dyno runs the power looks like a light switch (i even think the 2835 looks to come on pretty hard) are these really good for the street? surely 3rd gear would bag street tyres just coming onto boost, let alone trying to accelerate hard in 1st or 2nd? Sounds like fun, but frustrating when lesser powered cars beat you to 100!
I have a 2835proS on the way at the moment. Going to have to run R-compounds full time, as the 2530 already fries tyres with its paltry 220rwkw! :)
building a RB25DET with a TD06-25G, nice laggy turbo with good topend power, and a misfiring system to keep the turbo spooling while I'm off the throttle. The one that I've bought is a metal sleeve thingamajiggy (can't remember the name) so its not steel bearing or ceramic, and can withstand a lil bit more punishment than a standard turbo.
As a standard swap/upgrade for a R33 RB25DET i'd say get a 2530, but I dunno how they react to RB25DET Neo's.
Funky you have been talking about this setup for about 1 year now, when the hell will you get all these antilag thingamergiggies done?
SLY33
Is the 2835pro s going to fit on the stock manifold without modifications?
As for traction, good tyres and decent suspension setup helps alot!!!
SLY33
i hope so! i think it all bolts up. Kit comes with its own dump and all the lines. I think the one thing ill need is a new intake pipe as the compressor inlet mouth looks big, but im fairly sure its a blot on kit.
can someone with ~280rwkw comment on drivability? are these cars still fast at speeds below 100 or is it just wheelspin city?
While i love power, it makes you slower if you cant get it down!
Damn impressive resutls...are you sure it was only 13psi:confused: I have read of those sorts of power figures at 1.3bar. Is it a std RB25:
No its not standard. I dont know what has been done other than bigger cams, injectors, external wastegate, it was a import this is how it came. It was dynoed by Brad Sherriff in Tassie.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
