  • Replies 199
CC if it still has the factory turbo oil feed line then there is a high chance that it's cracked somewhere. if it's a braided aftermarket one, it's possible one of the fittings has come loose, or was not assembled properly. oil feed will not be too hard to replace. get one made of stainless braid covered extruded teflon hose. I did on my SR20, and felt much better knowing that it was there.
Legends, sounds like those guys have really been helping out :D to cromer exhaust centre :)
Yeah man I can't get over how cool those guys are. When I called their shop on Tuesday (public holiday) I think it diverted to David's house. He arranged for Grahame to come down to open the shop for me so my car wouldn't sit outside all by itself.
He had to move a truck outta the way and unlock the whole place to let my baby in on the hoist. It's gonna sit there while they paint.
They're freakin legends I can't recommend them enough.
Thanks R - that's what I thought, the fittings had gone but I looked and felt both ends and they seemed to be sitting in securely and wound up. When the engine was running oil was just beading on the line but didn't seem to be wet on either end near the fittings. :confused:
Anyway the agenda for my car at the moment is.
1. fix oil leak
2. full wheel alignment
3. fit ARC sump (more oil wee!)
4. fix couple of exhaust rattles
5. weld in oil catch breather to air inlet (engineering requirement)
6. fix up some lose lines that go to nowhere re: carbon canister (engineering requirement)
7. change mech diff oil
8. engine oil+filter change (due to #1 and #3)
And I'll probably go back to ask them to
1. change sparkies
2. change fuel filter
3. install my rear camber arms (depending how much)
4. fix the damn leak now that I've found it (depending how much)
5. look over it for engineering/look over it for shonkiness (depending how much and if I'm not too scared)
6. put in an extra exi-mani stud that was never there
7. put in pineapples
8. weld the tailshaft supports (nark's thingy)
While I know they'll bill me reasonably I'm scared to think.
Anyone wanna sponsor me some cams and/or EBC? :)
Damn cc you are still having a hell of a time with it. Im going to get them to do my exhaust, need to get it quieter. They really seem like good blokes.
No one should be sponsering you for anything! you already have more power then me I need to catch up!
Woot latest update:
Cromer Exhausts re-opened today and they said NO PROB car should be ready by Saturday easy.
That's including everything on that list EXCEPT nark's tailshaft solution. I'm going to go back for that because by the time I get them pictures and stuff and talk it over with the engineer I won't make it for the cefiro dyno day.
**** me they have good service. Thanks Grahame what a legend.
(Hopefully I won't be selling a liver or whoring my ass any more than usual to pay for it.)
Also I'm waiting to see how the car will go with the camber kit and pineapples installed.
Any thoughts on the pineapple setting? I'm thinking of having all bushes installed on top so it's rigid but not ridiculous drifty or ridiculous squaty.
Cool man let em know ya know me and you heard of em through SAU - I've mostly spoken to Grahame and he's the one that's been working on my car.
If you head over there you should see my car lemme know how she's lookin :)
They just told me my rattle (the one I thought was near the cat that I couldn't see) was the inside of the cat ha ha (need a new one).
So adding a hi-flow cat to that list above :P
Funny thing is, I think I know when it happened. Must have been when I was on the way there the first time and ended up driving the car in limp mode to their garage with all the flames flying out the back. I think that must have gutten the insides of the cat haha.
I hope this ain't gonna be too expensive :Paranoid:
nP.
Unfortunately mine has little to no oil in it so can't/shouldn't be started otherwise I'd say you can hear mine run and see how you like the resonator they put on my car.
It's still a little loud but not as loud as it was before. If I hit the lottery I'll be getting a full J-brand exhaust for that idling raspiness/breathing and full throttle insanity.
Right now I'm not happy with the way it sounds (sounds kinda like all the doof-doof sick lancers with the exhausts :) ) but I'd say that has more to do with the poo cannon it has (x force or copy).
Cool. They called me yesterday and said I won't be needing a new cat. Sweet. Apperantly the heat shield just fell off or something and was causing rattling.
Turns out my oil leak was that the inside of turbo oil feed braided line had detached or something - which would explain why I thought it was beading on there but couldn't see the source.
I did drop off some pineapples and rear camber kit to them however.
While I was there I checked up on what they were upto-
New sump (more oil yay!)
Crappy oil drain pipe that's kinked (to be fixed)
Custom cut factory catchcan (will fit in around my manifold and help the aftermarket catchcan)
Cromer sponsored drift s14
Cromer targa GTiR interior (mm)
Just got back from Cromer... Fantastic bunch of guys!!
Turns out I need a new rear muffler (mine is too small and trashed on the inside) and might need a mid muffler depending on what happens with the new rear. Im definitely booked in for Monday. So ill be loud on the dyno :mad:
Ok.
They did all my stuff my car was ready today (friday). I figure it ran outta rego so I'll drive it straight from cromer exhaust to procar for the dynoday since it's on the same road.
Final cost I think was $700 and supposedly they couldn't do the wheel alignment because they "didn't have specs". Whatever that means.
I'm not too sure I'm still impressed with them until I get explanation as to what they mean by SPECS??
Either way it cost a bit more than I'd hoped, I'm sure they did a great job but since it was mostly lotta little things but I don't see them being QUITE that much worth of time - what's everyone else think? Am I being unrealistic as to what mechanics charge? (I was hoping for about $500).
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
