Dyno'd my car today.
12psi boost my car would not go over 100kw - 98.3, 99.4, 97.3 etc
Something was seriously wrong and I was craping in my pants. Clutch slippage was first check, it wasn't that because the dyno has a 'traction something or other monitor'
We tried one other thing - the Crank Angle Sensor (or I'm pretty sure it's that). It was adjusted anti-clockwise slightly and we crossed our fingers.
First run we hit 169.1kw at the wheels! Which relieved me, greatly, and the mechanic. It dropped to 169.8 then a bit lower because of heat possibly, but by going to the dyno today I gained around 70rwkw.
Here is there dyno graph:
The mechanic assures me its safe, it is not pinging and according to the dyno the mixture is 'extraordinarily' rich.
PowerFC here I come!
Mods are:
- Pod Filter
- Turbo back 3" Exhaust and 7.5L Cat
- Hybrid 800x300 FMIC
- GFB Bleed Valve set to 12psi
https://www.sau.com.au/forums/topic/55542-my-100rwkw-r33-dyno-results/
Scary stuff DezertEagle.
After I installed my fmic and put my car on the UAS dyno with 11psi I got a scare too, I only made 6kw more at the rear wheels than when i had it on the same dyno with the stock intercooler.
A quick check of the timing and the base timing was out. They fixed it up quickly...Ran it again and boom 184.2rwkw! phew. hehe
Damn that base timing scaring the crap out of us. LOL
Mods are:
- Pod Filter
IT:40
intake temp 40degC??
sounds unusually high to me. when my car was on the dyno the IT was 14degC
from what i understand, shootout mode adjusts your figure if its deemed 'hot' so your real figure may be lower than what you are displaying...
(also, you should block out your number plate before you post something on the internet)
Yeh, I'm going to Unique Monday morning, hopefully they can find the optimum CAS position on my car.
IT - 40deg does sound suss and I don't know what's going on there either. Me and the mechanic were both just worried about the under 100kw readings my car was making.
I've recentl had a few issues with massive power dips running a RB30DET (rb25 head) on the stock rb20t ecu.
At the moment it makes 11psi on the stock acutuator, it hits a fuel cut and runs really rich (well in to the 10's).
I had a really bad surging feel. Advanced the timing & it smoothed out all the power dips/surges.
It will be on the dyno tomorrow to find out if an safc & some more timing will make it run near perfect.
Hopefully all goes well otherwise I have to limp it around under 4000rpm until I get the powerFC near xmas. ;)
  • 1 month later...
I seem to be having the same problem here, my car feels sluggish and slow
proven by an embarassing 19sec pass down the 1/4
I checked the timing with a timing light and its on 0deg
The timing marker is on the first orange line
the thing is the CAS has allready been turned anti-clockwise to the max
any ideas what could be causing it?
That graph looks funny... torque is exactly the same shape yet power is a completely different shape on those 2 runs.
Ie. The actual torque curve has stayed the same but just gotten higher, yet the power has changed from flat to a proper curve...
edit: actually no im just looking at the wrong plot, my god that first run looks like a push bike with a drunk dude peddling
You need to turn the CAS clockwise to retard the timing, sounds like yours is fully advanced! 15 deg is what it should be set at. Third white mark after the orange mark.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
