this waiting is killling me...
everything is done on the car, but now i'm just waiting on the plate from the engineer. it sucks when such little things are holding it up. i've been waiting so long i'm itching to get it on the road.
Not as long as some. :P
I am going back to the workshop this week to get my engine started on Friday, hopefully, for the first time.
  • Replies 580
I sure will :P I was going to take two!! :uh-huh:
just organised my alarm install. my greenslip is bought. comp insurance is sorted. so now it's just RTA and i'm done :)
fingers crossed for me boys.
yeah, I've got the receipt. I've also got my telegraphic transfer receipt so that should be enough. also finally found the original of my VIA last night which was a relief.
FINALLY!
18pages after I started this thread I have it!
Bad news tho. The worst being that the 4WD light comes on and there is a problem with it.
Secondly the car has been raped at the wharf. The GT badges on the side are missing and there is paint damage, the clips for the fibreglass bootlid have been taken and even the metal valve caps are gone!
Not good but its a nice feeling have a GTR race car sitting in my garage :)
My car is in Sydney, broker is getting it steam cleaned today, should be at his shop tommorow avo, and I am *hoping* to get it this weekend, but I'd say realistically I'll have it mid next week!
W00T.
Just for people's reference.
Purchased from auction in japan on 22/12/04
On boat (Kiwi) on/around 02/02/05
In Brisbane on/around 13/02/05
In Sydney 16/02/05
Will be at complience (same place as import broker) tommorow - 17/02/05
Should have it in my hands 26/02/05 at the latest.
So it took me about 2 months from purchase to 'on the road'
WOO HOO!
Do you have a signed copy of your purchase receipt?  Some people are having trouble with the RTA being arses.... :)  Make sure you also take your import approval.
LW.
that was aimed at me right? I had that problem
If the RTA's job was being an unhelpful bunch of asses that takes shiteloads of money from you, then they would be perfect :(
mark
good luck!
FINALLY!
could it just need fluid? or a stuffed up fuse in the engine bay or something
well I picked up the car today without any drama. didn't need a signed invoice. so I guess I got lucky there.
Car is awesome. plenty of bits that have been clarified now that make me very happy.
Main thing is that the car has an aftermarket gearset in the box which is awesome. tricky to drive with (no synchros on 1st, 2nd or 3rd) but now that I'm getting used to it it's amazing. car has a kakimoto ecu too. but it doesn't really matter as I already have a PFC anyway.
Anyway, I'm very happy and very tired. pics tomorrow.
Roughly how long was it from your cars came off the ship to when you guys actually got your cars?
also (random question).. but can the engineers certificate been signed by any engineer? my mates dad is a mechanical engineer (does boat engineers or some such work) and I could get him to maybe write me up a mechanical signoff?
well fluid appears to be within the right limits and the fuse seems ok as well. I'll drop the car next week to a workshop that is familiar with ATTESSA to get them to sort it out. Its a high priority as you can imagine :cheers:
mine landed in brisbane on 20th of Jan (from memory) so it took just over 3 weeks to get it cleared, delivered to sydney, complied, registered.
No you can't get just any engineer to do the sign off. In NSW they must be an RTA approved signatory. I believe it's the same deal in other states too.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
