Finally coming over guys!
about time i reckon... sadly the car is not accompanying me as i dont trust it just yet.
although it seems in good order finally.
so im flying over, staying with Steve-SST (many thanks goes out to him, bayley and his family)
Im in for 3 weeks, booked the airfares already so there is no getting out of it for me.
Plane lands a chirpy 7.30am on the 23rd, see ya's all soon :rave:
https://www.sau.com.au/forums/topic/55693-finally/
People,
Can highly recommend taking Ash out. He's a top bloke. I went to the SAU VIC meeting last tuesday, as you do when in melbourne for a couple of weeks, and Ash kindly extended his middle finger, i mean passenger seat, when this west aussie was looking for a car to cruise in. One word sums him up: Champion :)
Ash, I look forward to extending the invitation back when i'm back that way, no GT30 or screamer pipe on my car though mate.
Dave
https://www.sau.com.au/forums/topic/55693-finally/#findComment-1092880
just take me out farken :)
Dave - anytime mate. Im a pretty sociable bloke at the best of times.
Hope you werent too tired for work the next day though. It was a late night. i didnt get home till 1.30am or something :)
https://www.sau.com.au/forums/topic/55693-finally/#findComment-1093538
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
    • Temp = -21.052 X Voltage + 114   That should get you pretty close. Calcs based on two points I could do easy calcs on (30 and 70 degrees).   It also says your sensor should only read as low as 9 degrees when it maxes out at 5V, and should hit a peak of 114 degrees at 0V... Just as a heads up if you were going really cold places, or wanting to be aware when temps really go up with it.
    • you, sir, are a prince. good on ya.
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
