  • Replies 168
Posted Images
damn, its been a while since a last saw this. My car didn;t have abs. If i did, i wouldn't be stripping it, hehe. Still got heaps of parts boys/girls, but alot of stuff has also been sold. let me know what you want, and i'll see if its still there.
  • 4 weeks later...
the motor is available. it everything still on it, except: the ps pump is screwed, the air con is screwed. The exhaust manifold and turbo are off but still available. the loom is gone. the flywheel is gone. If you want the bare motor without inlet manifold, and accessories, ie just the head and the block. I can do that for $300ish +post. add on extra stuff.
boot trim is sold sorry. They clock on my car was part of the guage cluster. The clock you are after, i think, is the one from the r32 gtr and it sits on the cluster surround left of the steering column. I can't help you there either, sorry.
yeah, boot trim went quick.
i have the climate control unit minus the face plate. Ie everything works fine, its just missing the cover that goes around the buttons, and protects the screen. If yours just isn't working, then you can simply use you old cover. i got pics, leave an e-mail address.
Sorry, never had a stock cat back.
i still have the font steering rack. Its still on the car. It looks fine to me, but then i'm no mechanic.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
