apexi power fc
blitz frount mount cooler
nismo fuel pump
z32 AFM
AVC-R
dump pipe
NEW garrett highflow turbo (PM me if interested in this - avail. soon)
252 rwkw at 1 bar
Hits boost nice and early and does not drop off.
97' R33 GTST
-Turbo back exhaust
-Pod
-PFC
-Stage 3 Hi flow
-duel stage boot controller (turbosmart)
-Cooler (600x300x76)
-pump fuel
-14 psi
Made 211kw at the wheels.
Restricted by a 6,000rpm rev limit and injectors and fuel pump maxed out.
Edited by DNR33
R33 GTS-T S1
MICROTECH ECU LT12
850CC INJECTORS
PLAZMAMAN PLENUM
80MM THROTTLE BODY
ARIAS PISTONS
SHOTPENED RODS
FULLY BALANCED
HKS CAMS 256 264
HKS TO4Z
ON 25PSI MAKES 362RWKW TRIED TO PUT POST IN THE RB25 RESULTS PAGE
not sure why it didn't work for you, but i moved your topic in here for you. - Beer Baron
Edited by Beer Baron
R33 97 Series 2
Engine management - Stock ECU
Boost - 12psi
Turbo - STOCK
Coilpacks - STOCK (but taped up)
Custom Front Mount
Custom Intake Pipe
3" Exhuast from turbo back/Split dump pipe
Blitz Pod Filter
Greaddy BOV
220rwkws
:P
1997 R33 GTST series 2
HKS 2530 turbo
HKS boost controller
Apexi power FC
Greddy FMIC
turbo back 3" exhaust with metalcat
pod
95 octane pump fuel
1 bar boost
214 rwKw
Edited by mikel
post-10771-1165577843.jpgCar: R33 GTST
Mods:
Full exhaust, with very hi-flow cat
Bosch 040
Nismo fuel reg
Power FC
FMIC
Nismo 550 injectors
Exedy clutch
Z32 air flow meter
Turbotech boost controller running 17 psi
Slide hi-flow max oversize with VG30 rear housing
Edited by mickr33
RB25
260rwkw on 16psi on 95oct
The tuner tuned it really safe... but say's i could run another 10psi in it but the fuel is crap so i will have to wait.
Specs
Rebuilt motor (8.5:1 Comp ratio)
metal headgasket
Cams
Injector
z32
manifold
38mm wastegate
gt3076r
3inch exhaust
Edited by al_r33
hi, i drive an rb25 silvia.
mods
s2 rb25 det
garett gt3076 (ie.gt3037) .86
tial 38mm gate
delta fin cooler
turbo back exhaust
plenum
14psi on stock computer, afm, injectors and reg with 12.2 afr's
277.9 RW-KW....... my car is a freak.
Edited by drag-on silvia
S2 RB25DET
184RWKW (@5900ish RPM)
Stock Turbo/ECU
FMIC
Turbo Back Exhaust
HKS Pod Filter
9PSI showing on guage
Hit R&R pretty bad at about 5000rpm
Edited by VLT025
got my 94 series 1 r33 gts-t back today after 9 months in the shop getting engine rebuilt e.t.c. gt3040r 600hp turbo with a/r.82 exhaust housing. results : 274 rwkws at 17psi on shell v power racing 100 ron fuel. 346 rwkws at 25psi on shell v power racing 100 ron at 7000rpm @
link to dyno sheet: http://i52.photobucket.com.au
Edited by bigcarl
97' r33 gtst S11
- turbo back exhaust
- pod
- front mount cooler
- pfc
- 550cc injectors
- stage 3 hiflow
- z32 air flow meter
- adjustable exhaust cam gear
- walbro fuel pump (500hp)
- dual stage boost controler
- 16 psi
- 98 octane pump fuel
- 36 degree day
made 245.8rwkw. boost spiked at 18 pounds around 4500rpm then droped off to around 14 by the time it hit 7000rpm. desperatly needs an ebc.
Edited by DNR33
My latest run: 288.9rwkw with about 18.5psi at peak power
related mods are;
Ms k&n pod with custom fiberglass partition and 100mm uPVC CAI
z32 afm
china hybrid copy cooler
s6 rx7 550 injectors
power fc
HKS 256/264 drop in cams
adjustable exhaust cam gear set to 0
split fire coils and bcpr7es plugs gapped to about .9mm
HKS low mount cast manifold
HKS 38mm ex wastegate with 2 inch pipe plumbed in before the cat
HKS t300s turbo, .7 ar comp cover, T04s comp wheel (unknown trim) T3 rear end in .63 housing
3 inch pipe off turbo
5 inch catco metal cat
3.5 inch custom mild steel cat back with custom 3.5 inch mid muffler and 3.5 inch x force cannon
previous best of 274rwkw at 18.5 psi peak, changed the old hot dog mid for a proper muffler, gained 14rwkw and made 274 on 1 bar this time :)
edit: woops, this is a stock bottom end rb25 in an r32 btw :)
Edited by BHDave
Nissan Skyline R33 GTS-t 96
Blitz kkr430 turbo
Trust 600 x 300
3inch turbo back exhause
Apexi S-afc II
Turbo smart dual boost controller
600hp fuel pump,
fuel regulator
spark plugs
Forged oversized pistons and rings
Block and crank machined
16 psi = 266rwkw
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
