R33 GTST2
ApexI Induction Kit
Tomei Poncams
4'' Tomei downpipe
3.5'' HKS Exhaust System
Blitz Return Flow FMIC
Hybrid Turbo (Standard Housing)
555CC Nismo Injectors
NISTUNE (Z32 ECU)
Q45AFM
252KW @ Rear
302KW @ Engine
Max Torque 560NM @ 3900
@ 14.7 PSI
@ Shell V-Power Nitro+ (whatever that is)
http://www.shell.co.uk/gbr/products-services/on-the-road/fuels/vpower/what-is-v-power-nitro-plus.html
Turbo ran out of puff at higer RPM, would not go over 14.7 PSI.
Car is fun to drive with good torque/midrange.
Edited by Torques
98 R34 GTT
91k KM'S
Z32 AFM
HYBRID FMIC
Yellow Jacket Coil Packs
600CC DEATCHWORKS INJECTORS
HYPERGEAR SS1PU TURBO RUNNING 16 PSI (MAXING AT 17 BUT FADING TO 15) WASTEGATE CONTROLLED
FULL 3" EXHAUST
BOSH 044 IN TANK
STOCK INTERNALS
BP ULTIMATE 98 RON FUEL
340HP - SAFE TUNE
Tuned by RPM Dyno & Performance Morayfield (Peter Roma)
Same setup running more boost (20psi at peak fading to 17) with a different tuner (Richard @ All Star Tuning and Performance Brendale) 100k service and CAI box.
377HP (281rwkw) with boost drop (we stopped until supporting mods are done to take a constant 20)
Car is just plain savage now so responsive it's insane.
I will post sheet when I can.
Edited by RandomHero83
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
800cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
HyperGear Latest Ball bearing ATR43G3
4inch intake pipe
Adaptronic Plugin
Power so far is 395rwkws @ 23psi E85 Fuel
ATR43SS3 VNT Turbocharger.
It made 394rwkws on 23psi of boost so far
I must address this result was archived by a large size turbocharger using stock cams and stock cam gears and boost. It is not enhanced through larger cams or cam gears.
ss3boost.jpgAs shown, the boost behavior in reference to degrees of freedom given by the actuator controlling the VNT nozzles. The whole boost curve shifts to the left as the nozzles stayed in the deactivation position for longer.
Boost curve with VNT system fully engaged and fully disengaged:
I should be able to get 20psi by 3600RPMs with few more hours of dyno time like what the fully engaged and disengaged boost graph shown, then disengage after it reaches that point. As we were adjusting the boost controller for dyno runs the car experienced some ignition problems so we had to call it a day. It will go back for any other run once I have it rectified.
Following up on the ATR43SS3 BB VNT turbocharger
800cc injectors
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
Power so far is 407rwkws @ 24psi E85 Fuel
HyperGear ATR43SS3 CBB VNT Turbocharger.
Turbocharger reached peek power of 407rwkws on 24psi of boost
This result was archived by a large size turbocharger using stock cams and stock cam gears and boost. It is not enhanced through larger cams or cam gears.
This turbocharger had big turbo's top end while retains small turbocharger's down low. I've overlaid my result against result from a high flowed stock R33 21U turbocharger.
  • Like 1
1999 R34 GTT
Nistune Board
3" stainless exhaust from the turbo back, high flow cat
Front mount intercooler
Simota pod filter
Yellow jacket coils
HDI boost controller and rb20 actuator on 10psi boost
Edited by NZDRIFTER
  • 1 month later...
A few weeks ago I decided to change to United E85 from the Martini E85 I had been running in my R32 GTST.
RB25 Neo (unopened).
Vipec Plug and Play for R34.
260 degree drop in Pon Cams.
Trust TD06-25G Turbo kit.
Plasmaman intake manifold.
Deatchwerks 1000cc injectors.
Twin 044's
United E85 (obviously)
ALLSTAR Tune.
27348F55-F850-42EA-BFDC-0EDB4656C99D-392
Previously ran 182rwkw, untuned.
Fitted a high-flow turbo, and nismo 480cc injectors, and tuned at Willall by Martin to 245.5rwkw.
Pretty stoked with the results.
1998 R34 GTT
RB25DET
3" Turbo-back exhaust, high-flow cat
K&N Panel filter in stock airbox
Blitz return-flow intercooler
nistune ECU
Standard AFM
nismo fuel pump
Yellowjacket Coilpacks
IRIWAY7 sparkplugs
Highflow turbo of unknown origins
R32 10PSI actuator + R34 factory boost control
Just had hi flow done on my R33GTsT series 2 at JEM with a GCG hi flow r33 turbo.
Mods:
-Front mount
-3 inch full exhaust including dump with standard cat.
-AVCR boost controler
-Stock ECU, stock Injectors, stock fuel reg.
-Stock manifolds both intake and exhaust.
-AEM intank 355kw fuel pump.
-10psi boost very safe tune (for now until i feel like pushing more)
- GCG Hi-Flow R33 turbo
Result:
195kw@6000rpm at 10psi with heaps in the tank left. Turbo not really trying hard at all.
Had idle pully noise behind timing case due to silly me not replacing the pulleys when i did the belt, so once i do that the boost will be upped to around 14 or so.
96 model S2 R33 GTST Standard
550cc injectors
Stock exhaust manifold
HyperGear ATR43SS2 internally gated bolton version
3inch intake pipe
Nistune
298rwkws @ 20psi. 278rwkws @ 17psi. Pump 100 fuel.
ATR45BB turbocharger base result
Tomei 264/8.9 cams, Stock cam gears.
800cc injectors
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
Power 445rwkws @ 25psi @ 4500RPMs, E85 Fuel
S2 RB25det stock
Hypergear 21U R33 highflow.
Splitfires + 0.8mm platinum plugs
Walbro GSS341
Standard 370cc injectors maxed out.
FMIC, switched to Tbolt clamps on all silicone joiners.
3" turbo back exhaust through a quiet muffler, very good system
stock airbox
GTR BoV plumbed back.
Pretty common set up; tried and true. Drives nicely and has pretty awesome response, full boost by 3950RPM on dyno
Tuned by Toshi
Made 241KW at the rears on 15PSI, 618NM of torque. Maxed out standard injectors
HxhBLzW.jpg?1?7643
  • Like 1
ATR43SS4BB Alpha protype1 turbocharger
800cc injectors
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
Power 465rwkws @ 24psi @ 4500RPMs, E85 Fuel, maxing out injectors.
Thick yellow line corresponding to the current turbocharger, the rest is evaluation of ATR45 as base result.
Standard unopened RB25DET Neo
150xxx K's
Hypergear ATR43SS2 internal gate
Standard exhaust manifold
Standard intake manifold
RB25 S2 throttle body (deleted traction control and cruise control)
3"JJR Mild steel bell mouth dump pipe
3" straight through exhaust (no cat)
R32 GTR intercooler
Xspurt 1000cc injectors
Standard fuel rail with 4mm spacer
Greddy Profec B spec II
R34 NISTune ECU
20psi bleeding off to 18 up top
Edited by iruvyouskyrine
R33 gtst S2 Stock rb25det with turbo back exhaust, after market low mount manifold, r34 gtt turbo op6, nismo 740cc injectors, front mount all controlled by a haltech platinum ecu with boost solenoid. Running 14psi tuned by Ed at Autotech.
197.7kw at the wheels
1997 R33 GTST
320rwkw on 20psi
Turbo: Hyper Gear SS2
injectors: Nismo 740cc
AFM: Z32
Computer: Power FC
Exhaust: 3" JJR dump, customer 3" cat back with X-Force Cannon muffler at the rear
Intake: 3" metal pipe
blitz Intercooler
aftermarket fuel pump
Running E85
I have a s1 r33 with
fmic and custom pipes
tomei fpr
bosch 023 fuel pump
custom rebuild turbo
Splitfire coils
Greedy forward facing plenum
80mm throttle body
3 inch mendrel bend exhaust with custom dump and front pipe
550cc injectors
new fuel rail
Its making 361kw at the rear wheels on 22psi and 306 on 15 psi
im yet to get a new ecu and forged internals and cam.
here is a link i build me engine off
http://www.nzefi.com/packages/power-upgrade/nissan-skyline-r33-rb25det/
cheers
R33 GTST S2
GCG High flow / garret 3076 GTX turbine rotor & compressor wheel
Apexi SAFC II
Greddy ProfectB II
Shortened heavy duty actuator arm
3.5 inch exhurst system
Spitfire coils
RH9 alternator 130A
currently running 276rwkw at 15psi need to add bigger injectors, fuel pump, and more boost
to get more out of motor
