PowerFC ECUs w/ Hand Controllers (NEW & under $1000!)
Adrian,
There is no need to post such inflammatory statements. If Customs chooses to impose GST, it will have to be payed, at least that's my understanding.
I have had a lot of parcels from overseas. Sometimes customs just lets them through, othertimes they decide to charge duties (and this is with parcels properly declared too). Go figure.
Lucien.
  • Replies 247
AP engineering version? hope this dosent apply to me
i got a R32 GTS-T and if i can get one definately put me down for one at that price.
I'd be down for that too
It is the law that GST will have to be paid. But by sending them to individual addresses usually they go straight to your door without any hassle.
Come on lwells, this is openly suggesting that when they are sent to individual addresses, you can avoid the GST.
Open your eyes mate.
Adrian
well, no, you don't have to pay GST on an item purchased overseas... as the service takes place overseas. The only time you'd have to pay GST is if you paid Duty at the customs, because you'd be paying GST on the duty... kapish? Its the whole tax on a tax thing... old news.
Awesome price guys. If anyone is only interested in the Power FC, I am in the market for just a Hand Controller. We might be able to work out a deal. PM me if anyone is interested.
Just as a suggestion, it might be wise to look into the possibility of depositing the $$ into a holding account which only gets released to the seller when the goods are received.
20k is a bit of money.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
