  • Replies 1.2k
Has Beau been handing out those "Free sex" vouchers again? Dont be fooled, sure it sounds good but the "free sex" in question has to be with him and lets just say Beau's idea of sex is.....interesting?
dont ask me how i know..........
i'll be out again this week, Teh chicken poxorz have m3!!!
yup i wont be there this week me and gus will be at ACADEMY! and andrew i told you its not chicken pox its gonorea and the free sex isnt with me you told me you wanted sex with anyone so i thought the vouchers were the way to go cause your definatly not touching me you michael jackson try-hard. back on topic, hope ya'll have fun tonight you probly wont win though cause i wont be there but ill encourage you to try anyway :D :jk:
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
