Chucked my R33 on the Dyno tonight for the first time since i got it. On low boost (0.5 bar) it made a 256rwhp :P. Then after trying to find out how the hell the Blitz EBC worked we managed to get it to do a run on 1.4 bar and and it made 320rwhp at the rev limiter!! This was due to how we had set up the boost controller, so its not really at the cars max power. We were short on time and never ended up fiddling further after this run and left it as is for now :D. I'm real chuffed anyway and i just had to tell the world :rofl:
https://www.sau.com.au/forums/topic/56314-dynoed-my-car-4-the-first-time/
yeah its got a fair few things done. Its a hks GT2835R turbo with the 0.64 exhaust housing, greddy plenum are the main things things, plus the usual stuff like after market ecu and intercooler. I'll scan the graph tomorrow at work and post it up.
I saw 1.4 bar and thought arhhhhhhhhhhhhhhhhh.....
No mention of aftermarket turbo at that stage....
Plus he said going from .5bar (which is pretty much standard) i thought poor little thing...
Good work tho... Nice boost controllers... Ive gone from apexi avc-r to BLITZ SBC-i-D III
hey i was wondering...would you need a special manifolds for the HKS 2835R ? coz i was thinking of getting one for my r33 GTST but unsure if they would fit bolt on.
my hks 2835 uses a 0.71 exhaust housing but is a t25 flange
Will bolt on if its T3 flange
the dump pipe is a totally different flange. I just started pulling it apart so i'm not sure what time it does at the drags and probably won't get to find out for a while.
there's about 10 different version of this turbo. Mine is the GT2535R Pro version. Has internal gate, 0.7 comp cover, and 0.68 xhuast housing with a T3 flange. Its on the HKS website -> My Turbo I have the HKS exhaust manifold so i'm not sure if it would bolt onto the standard manifold or not.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
