goodbye to a good car..
Guest Boxhead
 Share
  • Replies 54
I'm the individual responsible for destroying Boxhead's R32.
Im sure most of you are expecting the story to relate to dangerous driving and speed. But both Michael & I know I wasn't speeding and it was just an accident.
So what happened??? as we approached the corner I braked and released. Then midway through the rear was upset and broke free, I counter steered as best I could but we slid sideways into a white refelective marker post and then into a cane field drain, the car started rolling and came to rest on its roof.
As far as injuries go, both Mic and I got ourselves out of the wreck and walked away. I must say today Im feeling it, for those who don't know I'm a big boy over 6ft tall and as you can see from the pictures there aint much headroom left. The fact that we rolled twice and neither of us even required stitches should give some idea of how we werent speeding. (of course if the drain hadn't been there we would have spun off into a dirt field and driven home)
So I now owe Micheals mum a sum of money, which it took a while to sink in but I now realise how lucky I was not to owe her a son.
To finish of the night I get fined for Neglegent driving, $180 and 3 points. I must say I've know friends in single car accidents in QLD and they havent been fined, I didn't cause damage to anything apart from Mic, Myself and his car. I dont get that?
So ends the post I had hoped to never have to write
Karl
Nizman
Guest Boxhead
yes... i would like to ad now that karl has said his peice.. that it was a culmination of things not in our favor that added up to what happened, happening, to be honest, i dont think anything else could of happened to us... thanks karl for doing what you did to try and come out of it... you did your best. and thats all that can be asked...
also, insurance shjouldnt be a problem for me, but it might be for mum, never had a claim till i got this car, 2 claims in about 2 and a bit months lol...
also i saw the car today in smash repairs joint, sadly car has gone to skyline heaven.. but i think that karl having such a strong head saved him :) coz lookin at it i had to move seat back a bit to fit... im glad were both ok. the car is replacable to some means... human lives are not...
Michael
ps, thanks for all your thoughst etc, and thanks to dave, and another friend who have been helpin me drive here there etc...
I am glad no one was hurt, which is the most important thing
Michael was hinting on a turbo on saturday as well :)
The car looks nice. Pity it is all gone now
Go for another R32
Also michael where did yo get the car repainted as well
I am interested to repaint mine either to silver and put more glitter or a midnight purple
Go for another R32
BOXHEAD SPEAKING ---
i got it painted at south tweed auto smash repairs...
umm, they were great, they did inside doors etc, so it looks like it was originally that color, they did inside boot... umm yeah.. i would recommend them, but it might be a but far for you to travel etc...
 Share
    • What are the torque specs for those 6 bolts on the retainer plate and 4 oil pan bolts? I'm currently tackling this job during an auto to manual conversion... I thought this would a 5 minute job!
    • Tryna decide if I should get a skirt coating on my cp 2618 forged pistons that im about to order. Anyone have first hand experience with a forged RB with coated or non coated piston skirts? Is it worth it and does it make much difference? And for people who went with 2618 pistons with no skirt coating how long has your engine lasted? The engine is an rb25/30 and main concern is  that It will be a daily car and will probably see a fair bit of short distance driving, have been told by my machine shop and my tuner that generally a forged engine lasts around 40,000kms before needing a rebuild. Would a skirt coating make much of a difference? cheers
    • From now on read it as minus 5 and minus 7 instead of dash, and you're correct...
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
    • You're confusing two different responders and more than one issue. The stock Neo ECU boost sensor is used by the ECU for protection purposes. It is essentially only an overboost sensor. It is not used for determining engine load for fuelling or ignition purposes. That task falls solely to the AFM. Any aftermarket ECU that either has an onboard MAP sensor or a plug in one, will use the MAP sensor as the primary load sensor. Or I should perhaps say "can", rather than "will", because some of them have the option of using other primary load sensors. That MAP sensor is not for the same function as the stock Neo boost sensor. The reason I recommended against a plug and play ECU is that they are intended to run a particular engine and usually in the car that the particular engine came in. So, if you have a transplanted engine in a different car, with some parts of the original missing (such as the boost sensor, for example) and therefore likely non-standardness of the loom and its insertion into the car's loom, then it is very likely that you will run into the same problems with needing to fix up wiring to make it work that you would with the stock ECU. And, if doing so for the stock ECU is enough of an obstacle that you start considering a standalone plugin as a solution, it should become clear that the plugin is quite possibly not the solution you'd hope it to be. It would just lead to more of the same type of problem solving work to get it going. In the above paragraph and in my earlier post, the lack of the boost sensor is not critical. It was just used as an example of something that we knew you did not have right, such that the stock ECU would not work. I took that as an indicator of a reasonable probability that there were other related problems hiding there.
