thoughts on new sticker design (pics)
Ok, as some of you will know i have been given the task of making some SAU stickers for club members etc. i serched for (SAU LOGOS) on these forums and i came across a few ideas from other members.
I ask gary1, what he thought of the idea and we agreed i would make a few samples.
Today we got around to cutting the stickers , there are two diffrent styles. i have sent 8 of each style to gary1.
i just stuck one of each on my car and took some pics so i could get a feed back from YOU !!
Please let me know what you all think.
https://www.sau.com.au/forums/topic/57512-thoughts-on-new-sticker-design-pics/
That's some nice spamming for SAu Mr Sparkle :rant:
I'm with Mase on this one. I like the last one. The red and silver on the back panel. Can we maybe get just the url's done as well www.skylinesaustralia.com but with the SAU bit in the middle a different colour or something? Just a suggestiong. Just thinking of something like that to match the other ones.
The first two that Melv has posted if what's printed on the buckle of the lanyard that funkymonkey down south has made. Looks awesome on there. I just like the slimmer longer one. Rather than the tall skinny one?
... If that makes sense
I like those ones the way they are.. not too cluttered... and you can still read it.
like the "set" we've got now is the two side window ones and the long url one.. How does that one on the panel look if you squash it down to fit that rear glass bit?
i could do that
have a set. like two of those long ones and a www.skylinesaustralia.com or www.sau.com.au sticker on its own.
:type:
I like them all tops work dude!!! :(
Left you a voicemail on your mobile too bout the club stickers just to see where they are at (sorry for hijacking thread).
But yeah AWESOME!
EDIT: Hey can you make stickers which are see through from the inside? so you could make a massive one for the rear windscreen and stuff? Prolly cost a fortune though I'd imagine :) The ricer in me has to know :(
Wouldn't mind a mirror image one to go across top of the windscreen, and or straight one for top of the rear screen. Don't fancy putting big solid stickers on the rear quarter glass. Might cut down the rear peripheral vision too much. I liked the origional small one for that area. Like the big panel one though, maybe a dot com on the end....everyone knows to put the www in front.
If anyone feels creative I'm looking for designs to put on the white 2 door (semi sedan Strutto???)
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
