Originally posted by macka
How did you Know i was a whore?
Sorry I only "do" turbos :lol:
Ya gotta pick me up tho im in Morley ;):D
I'll make speciall blow off valve sound every time my auto changes the gear! :lol:
send me the address via PM if you wanna go!
Bring that fancy camera with ya You can be pabarachie!
cheers
Joe
Originally posted by Pva_Glue
sorry No drinking in my car!
cheers
Joe
Aww spoil sport
Get ure point though Joe. I spilled coffee on my passenger seat AGAIN today exactly the same as i did on the way to MC, lucky i got dark seats:D
Oh oh dejavu :Paranoid: maybe i will beach it again:lol:
Originally posted by 25GTT
Heya guys,
Yeah the SAFC does air and fuel mixtures but the ITC does Ignition Timing so basically the igniting of the air and fuel i'd say. So now with these 2 bases covered it is pretty close to haveing a Apex Power FC but a bit cheaper. Apparently verhy Highly modded cars run the same combo SAFC with ITC so it musn't be too bad.
Don't mean to be controversial but an S-AFC/ITC combo is nowhere near a PFC for engine management.
They are very very crude devices by comparison.(but very effective for what they are)
The reason they don't sell the ITC's anymore is that if you are going to the trouble to control the ignition as well as fuel you are better off with a PFC
Cheers
Chris
Cheers
Chris
HUH?
What if you already have an existing SAFC installed it may be a better option to get the add-on ITC they may not want to take out safc to replace with a whole unit pfc and more tuning..
Or a car may have good original fuel curves and only benefit gains from timing control..
But i agree I would get a PFC as well if i had a choice any day..
AAAAAAAAAahhhhhhhh no drinking your no fun Joe..
You didnt seem to mind the other week...
Have you installed your NA Noise maker yet?
Originally posted by IMACUL8
Power FC for sure .....
cost a little more but MUCH more options and functionality
Dan
Yup as IMACUL8 and R34 said PFC has more controlling points and better all round bit deerer. However as mentioned i have heard that some big HP cars have the same setup : SAFC and ITC. PFC's are better but for about the $600 i saved i could make up the horsepower elsewhere....or new clutch:mad: so yeah bang for buck maybe this combo is better, could be wrong though but will soon find out i guess....
Due to my whinge before I am pretty sure i might be able to get free install due to the time taken for FMIC to get here. Already was getting it dyno tuned for the SAFC with the new FMIC so kill 2 birds with one stone whilst on the dyno... so have spent about $1000 for that combo fully installed and dyno'd...
The pimp and the whore will be cruising together i hear tonight! could luck boys.... don't mix business with pleasure if you know what i mean :shake: If you do though make sure you invite our new prison friend bubba for some brown love..... ;)
Have fun tonight everyone! might meet yas for a minute!
There is something between the AFC/ITC and PFC.
That's the emanage...I'm still having teething problems with it re timing control but that's something pecular to the 34.
They are an amazing bit of gear when fully optioned and even include a boost cut override option which you'd have to buy separately if going with the S-AFC
14.0 for 400m with S-AFC....13.6secs with partially tuned emanage(Car feels like it's good for low 13's with more practice)
The emanage really smoothed out the power curve of the 34 and produced more power down low because it's that more acurate
The S-AFC is great for minor mods but I understand that the ITC is not really necessary on a 33. All the S-AFC does is go between the AFM and the ECU to change the input signal signal to the ECU to "fool" it into thinking that it is elsewhere in the load map and thereby adjusting the injector output.
Cheers
See ya tonight
Ahh yes the E-manage. If you have a few dollars Godfather but can't afford the PFC and you don't have the SAFC perhaps that might be the way to go.... coz i had the safc i thought the ITC would be the way to go. Starting from scratch i would at the moment go the PFC however the E-manage when out of it's teething problems would definately be the way to go for bang for buck as R34 mentioned!
I think you said they sell for about 1g didn't you say R34... add about $200 for installation and dyno and that aint too bad only $200 expensive than what i have but would control more points of the ecu over my combo.... no funky blue screen though:D
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
