is yours a S1? Are the replacements from a S2? Because the S2 had the ignitors inside the coils, and they won't work if you already have an ignitor pack for your old coils.
yes they have to be in specific order if you leave them on the bracket. but as long as the plugs all match up to corresponding coils then I can't see a problem. Check what Morgs said. Earth is often the problem. Plus check the basics as it may be a coincedence but it might not be anything to do with your coils. might sound funny but it have seen it before. Check to make sure you are getting fuel and spark. Have you got a HEI (High Energy Ignition) tester? if so.....use this to test your spark. If not...go and buy one...they only cost five or ten dollars and it'll show you if you're getting the required spark from the coils.
hey guys.. f**k knows what the go is..
ive put the old (no good coils) back in, and it fires strait up..
try with the new coils. and nothing.
its got me stumped. so the cars still running like shit. and ive got these coils ive just purchased that appear to be no good to me.
they came from a S1, but are defently differant.
My S1.5 (S2 engine) has '533' coils and I have a S2 coil (from a S2 car/engine) that had '6xx'.
Sounds like you have the wrong coils (ie your mates car was a S1.5 with a S2 engine and your car is a S1).
pull off a rubber boot from one of your coils, and one of the purchased coils.
I purchased some that were missing the little spring that sits inside the boot, and the ones I bought had corroded / stained metal.
I cleaned them up with bi-carb soda and steel wool, then put the spring in (dunno if the spring makes a difference) and they worked a lot better.
But from the sounds of it, sounds like u got the wrong coils
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
