Ok, got the S-AFC tuned, and picked up an extra 15kw and 60Nm at the wheels. Now, this is weird because the power seemed to be quite low (166kw after tune) but Mark said that it was quite a good amount of power and that usually the other Skylines he tunes come up with around 145kw. But also, the torque seems to be monumental, it was around 640Nm!
The thing is he did the dyno runs in 3rd gear, because he said in 4th you run into the speed limiter. Am I right in thinking that having a higher ratio (3rd gear) would increase your torque and decrease your power, when compared to a lower ratio (4th)? It seems like that to me anyway, when considering the figures and Mark's comments about them. Also considering that the stock torque of an R33 GTS-t is under 300Nm, there's no way that I'm running double that right now.
The car still blows a bit of black smoke, but that's because he deliberately left it running a bit rich when I have the hammer down so that it doesn't ping on really hot days. The PowerFC as far as I know has temperature compensation so it can be eventually gotten rid of once I can afford that.
Next step is going to be a custom dump pipe, with dyno runs before and after (he said he likes to show the customer where their money is going - big thumbs up for that!) and eventually, either new intercooler plumbing or a new intercooler (my current fmic is very average).
Watching my car get sideways on the dyno was a damned good sight indeed :)
  • Replies 63
great results, but its a little bit of a shame they are in 3rd gear...!
wot a/f ratio was the car running stock, and wot was it running after mark tuned the safc?
seat of the pants, how does it feel?
how much did mark charge you for install and tune?
i'm going to see mark tomorrow morning to enquire about a few mods. hills apparently do a front mount kit for $1800 that is a micks metalcraft fabrication - can anyone comment on this kit? this is fairly reasonable value considering a jap kit will be close to 2k depending on who you take it to...
am also looking at a dump pipe and front pipe, i dont know whats out there at the moment. apparently www.arrowdiff.com.au have dump pipes for about $300, CES racing have a good range apparently (probably abit pricier) and you've got the normal jap range for about $300 + freight...
The A/F ratio varies, deliberately. Mark kept it in the high 11's in the high RPM range because he said he was worried about detonation. He said he could have pushed it into the 12's, but with the last tweak he did there wasn't enough of a power gain to warrant increasing it further. I trusted his judgement on the matter :) But on the most part, until it hits around 100kph in 3rd gear (whatever RPM that is) it's low to mid 12's. Originally it was mostly high 11's and heading towards low 11's at the top end. I'll scan the dyno chart and upload it this weekend.
Cost was only for the tune, because I'd installed it myself a couple of weeks ago. That was $140, I don't know what he'd charge for installation.
The dump pipe he uses is built by him so it's fully custom. He talked about running an external wastegate as well, I think I might go with that, but it depends on how much extra it costs.
I don't actually know why the dump pipe is such a separate item from the front pipe, to me it looks like they should be the one and the same piece. I guess it must have something to do with the wastegate.
My car goes into Hills this Monday for the works:
Turbo
Boost Control
FMIC
ECU
Injectors
Custom Plenum & Throttle Body
Custom Fuel System
Front , Dump and Hi Flow Cat
I'll let y'all know how it goes - I'm trusting that i'll end up with a weapon - I've been waiting for 6 weeks for (a) Parts and Worksop availability and (B) When I can put the car in. I know it will be worth the wait - I'm just hoping I can show it all off at 2Rismo's Dyno day next weekend !!
BTW - Anyone who thinks that they are getting work done at Hills next week is mistaken - That week is reserved for me !!:) :) :):D :D :D :D
Originally posted by tlai909
640Nm sounds a bit hard to believe...
I'm thinking PowerFC + my AVC-R now.
T.
Have a look at my dyno readout. I was actually mistaken, the torque was 641 when power was at its peak, but the peak torque occurs earlier and is over 700 :)
Anyway this is why I asked the question about it being in 3rd gear rather than 4th.
Wouldn't that blow gearboxes?
640Nm is more than what a supercharged Jaguar does :eek:
Quite Frankly, thats because the dyno run was done in 3rd gear. If I did a dyno run in 2nd gear, I'd probably make 800Nm+
The gears/ratios act as torque mutiplier...
Turbo
Boost Control
FMIC
ECU
Injectors
Custom Fuel System
BTW - Anyone who thinks that they are getting work done at Hills next week is mistaken - That week is reserved for me !!:P:D:) :) :) :) :)
Hi there, what turbo is going in champ? and which ecu. also how much is the plenum and throttle body setting you back?
Cheers champ..
:uh-huh: :burnout: :shake:
  • 1 month later...
Any news after ur upgrades Brendan ?
Im wanting to get the front pipes of my car done and after not being able to find anyone decent in my area i think im gonna have to travel to Hills and wait 8mths to get it looked at.
Damnit i got the money now grr
Hey Guys,
Yep got most of the mods done, just the hi-flow cat and final tune to go.
Results so far:
Before : 150rwkw
After : 220 rwkw on low boost (14 PSI)
Tomorrow it goes back to get the cat and final dyno tune, now that everything is run in, we'll be able to do high (18 PSI) boost dyno runs/tunes.
Expecting 255-260rwkw prolly can get more, but poof goes the head gasket......
PS - 1 day after I got the car back (220 rwkw) I had to change the clutch cause she slipped when >4000rpm and loaded up. THe std clutch just can't take the HP.
I won't post the costs - but if you like the figures and have seen under my bonnet - (and you can wait for the work to be done) then go to Hills and tell Mark that you know about my car and I'm sure he will look after you - Yes, the wait was worth it.... And I have more to come........
Cheers,
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
