My supplier had 10000pcs of cooler landed last week.
Polished Surface
- Core size 600x300x76mm
- Overall size 780x300x76mm
- Compressed air flow rate = 750 cubic feet/min, rated 850-1000 max hp
- Working pressure = 35-40 psi
- Pressure drop = 2 - 5 psi @ 35 psi
- Hot air temp = 0-150°C
- Universal front mount fit
- Comes with mounting plates and bolts for fitment
- Core in fin (Bar and Plate)
- Hybrid OEM core
- 3" in/out end tanks
1 pcs $330 delivered
2 pcs $320 delivered
5~9 $310 delivered
10~ $300 delivered
one cooler come with a 2.5 to 2.75 reduces for free.
Also avaliable 450*300*76 and 600*300*105
All the coolers are included life time warraty
:P haha very funny. This guy is sneaky
Well if you guys want a bigger picture then go here
http://www.skylinesaustralia.com/forums/sh...ead.php?t=57896
first he is his own customer and boasts about his company then he goes and steals my picture. He doesn't even have his own picture!! mmmm
Think about it guys!!!! Play it safe......
Actually I'm thinking of buying coolers from you too, seriously. How much for 500 coolers. Can you please provide me with digital photos of the coolers!!! side view front bottom and back. I will need them to be atleast 2048 by ...
dear rmahnovetsky
if you want 500pcs that's not worries we got heaps of them but for 500pcs you need to contact me on mobile and we need to sit down and talk coz i dont think you will take 500pcs as you don't have that amount of cash...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
