pressumed wrong.......RB25
yes, but this IS an RB20 thread :P
Anyway, should have the money soon for a full microtech retune, dyno run and to fit bigger injectors.
Currently running 9psi on the RB20 with twin T28's, full boost at around 4.5k.
Going to up the boost to around 12psi, see what she does.
who cares if its an RB20 thread theres people putting there silvias and so forth in saying yeh ive got sum power in my SR or CA......so i decided to share, quite simply put, why descriminate engines and say its just an RB thread.
THIS is a RB20 thread!
If you want to talk about your *fast* 25 then start your own thread!
Mad RB20 In the works.
Super T70 Turbo
750cc Injectors
HKS drag cooler
Custom stainless exhaust manifold and dump pipe etc.
Dyno and 1/4 mile time to come... ;)
Hey looking forward to hearing about this ride.
Turbine
anyway, put my RB20DETT R31 2 door on the dyno, for a full tune and bumping up the boost.
Got 182rwkw @ 7000rpm on 13psi of boost in 5th gear. Dyno wasn't a dyno dynamics and this dyno was known to read lower than dyno dynamics dynos so meh.
Huh? 5th gear??? If so that would be some crazy power wouldnt it?
yea gears make no difference, the guy just decided to run it in 5th, guessing to maybe avoid wheel spin and get a clean run
as for responsiveness, it isn't great, but im used to it, and once it passes around 4000rpm, it pulls like a fkin steam train. Haven't really paid much attention to the boost gauge, just the tacho, seeing peak power is made so damn high up in the rev range, with a dead stock top and bottom end, so i couldn't really tell you when full boost is reached, suppose i could check tomorrow :rofl:
To be quite honest, im kinda dissapointed, i want MORE! :(
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
