SFHS Hits Banzai - Report (LONG WINDED)
mate i dont care if ur a member of the St Lukes Prespetarian Association dont be affraid to say hi ;) always open to meeting people with similar interests and anyone interested in dorift0 :thumbsup:
  • Replies 73
mate all that smoke coming from the rear end.. you might want to look into that :thumbsup:
soon as I leave VIC interesting stuff starts happening down there - good to see anyhow. It's also good to see you're not afraid to take the car out there, or even further - let somebody else you hardly know do it instead ;) 95% on this forum would never even consider it.
More people should get out there and give it a try.. whether its drift, track or to a lesser extent drag (imho) .. its the best shit you can do sitting down. Nissans are built for thrashing..
i have to agree... everyones like "man... it will die after 2 laps"
im sorry... but it will if u dont look after it and maintain it... the engine in the cefiro has been maintained well before it landed and i changed every fluid in it before taking it out and will change it again now that its been taken out on the track and get the engine checked again to make sure its still in good working order.
like u said... this is what these things were built for... people get scared of importing cause theyve been thrashed... course they have!!! but its not like buying a thrashed holden or ford which is made for cummiting large families and pets.
and yes... that was the most fun i can honestly say i have ever had sitting down... apart from having sex sitting down... altho it was definately more comfortable and less messy lol
do it.. DO IT... DOOO ITT!!!
damn nerds!!!
lan nerds!!!
ive never lanned in my life.... i swear...
that CAT5 cable in my room was stolen from a nerd in my more rebelious days... its all good sameer... when ya get em.
Nice mate ;)
Can't wait until I can get out there too give it a bash (hopefully not into a wall :))
Only 2 things bothered me about the day:
1) FLIES FLIES AND MORE FLIES :crazy:, and
2) an hour (or more) worth of burnouts and bikes...
46n2
46n2
yeah i spent the burnout session in the pits... how boring watching crap heaps do burn outs and bikes doing monos...
there will be a prac day coming up so i suggest gettin out to it and giving it a go :)
might go too if i have enough cash
The "trick" bikes weren't that tricky.. pretty average.. I didn't even get out of my seat for the burnouts..
Went down to the pits to talk to a mate who drives the Carizma car for 5 mins, went back to my seat and remained there till more action was happening.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
