Originally Posted by EVL032
no iam not actually i would rather the RB20det. parts r easyer to obtain....BUT if u actually read the original post u would see that we were arging wheather it was just a FJ20 with microtec, xhaust, FMIC now at 180RWKW that proves i was right no way is that an FJ20 with only those mods.....sooo yes i was right
say what u want im telling you the fj20 is stock like u said computer and cooler and it is lossing boost so take that rb20 home and let it sleep for a long time
  • Replies 83
Originally Posted by Nismo_R31
can any1 confirm that a stock fj motor with 15psi , microtech, fmic, exhaust, air intake. can make 180rwkw?!
and i got the dyno report of it lossing boost
what turbo was on it though? i know a few DR30 boys who would love to get 180rwkw from a stock turbo at 9-15psi????
no that wasnt the question of this topic i was saying is there a chance that he can only have what was said that is the thread!!!!!! 4 all i noe he has more than claimed as i believe!
thanku[/quote the skline lost by 2 car spaces and he kant hack ... pepl said he wantz 2 get a biger turbo 2 race the blue bird and i no the blue bird is stock
itz got a coller ,computer and its lost boost 4rm dat and its hiting 9 psi
good luck finding ur FJ parts boys :ufo:
mate whats this all about?
you lost and now your jealous? cant think of anything alse to give FJ's shit about? get over it dude
LONG LIVE THE MIGHTY FJ
when moving in a straight line, boot to the floor in 2nd, it will wheelspin from around 3k RPM onwards....come off the clutch a little to quick into 3rd and its wheelspin again to redline....come off the clutch hard into 4th and it wheelspins for a bit, then the roadspeed catches the wheelspeed.
it also sits on the brake in 2nd at 1500rpm quite happily :)
peak power is not the way to make a fast car....just a dyno queen....
i think you need to close your wallet and do some research.....
lol...funny thread. FJs are a great motor, with a freakishly good std head, so forget the sad turbo and ECU they come with...with the right aftermarket parts they make a great engine
As for wheelspin how you describe...for gods sake spend some money on susp and tyres. My RB20 makes about 222rwkws and i struggle to get wheelspin shifting to 2nd, sure as hell cant spin tyres into 3rd:)
probably because a four cylinder is quicker than an RB20..... thats why i have one  :Bang:
Then a single cylinder 2Litre must be sik! :D
There's a fair bit more to power figures than number of cylinders (and displacement for that matter), infact a 4cyl vs. 6cyl is more likely to have MORE TORQUE but LESS POWER. Torque gets you off the line so in a traffic light drag like this the 6 is probably at a disadvantage. Power is essentially RPM x TORQUE so the 6 which revs better has the higher power figure.
There are so many variables in a situation like this, the diff being a big one, in any car if all you changed was that to run a higher ratio than stock you'll give plenty of other cars a good run. You might just top-out @ 140 kph though! :D
P.S. Well done the FJ20, having been in my ex-gf's little bros bluey with one i know they have some serious power, but i'll stay with my RB20 for all the aforementioned reasons (age/parts/etc.)
Guy's got some figures for you to mull over.
I purchased an Fj'd BB which had a Dyno sheet showing 220hp (165Kw).....
Pulled motor down and found Broken piston....
All this thing has is wolf V3, 15PSI.... 550cc injectors everything else stock...
Still awaiting tune on rebuild but have been told to expect some where between 180-200 Kw when done....
So Give me an 1100kg Car with an Fj any day.
Give me a 1300kg car with with an RB, a nice new style interior, quiet smooth drive and no whistling windows any day. :(
My RB20DET with a stock airbox, stock ecu, 3" exhaust, fmic & boost (15psi) made 164rwkw.
Without the fmic it made 152rwkw on lower (12psi) boost.
With an ecu (wolf or powerfc) the 152rwkw on 12psi jumps to 170rwkw with the same boost level.
The small turbo runs out of puff and will only stretch another 5rwkw or so with higher boost.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
