Right, blocked the rear outlet from the pump, and also the return to the reservoir.
Haven't yet swapped out the Hicas rack, but there is Power Steering fluid pissing all over from somewhere or other. I thought it was from the main return to the reservoir, so replaced it with a braided hose, but after taking it for a run out, there's an explosion of fluid all under the engine, hoses, suspension-everywhere.
Is there a possibility that the rear outlet being blocked is causing excess pressure in the system?
nope...we have had no problems at all with the setup, and it has had quite a workout last week ;) All I can suggest is that you follow every line again :(
Well, it's coming from somewhere:D Can't tell exactly where as it sprayed about a litre out yesterday, so I've taken the vanes out of the rear of the pump to see if that'll help.
I don't see how it could come out of the rear output hose that is disconnected, (where I thought it was)seeing as how the return to the reservoir is removed and blocked up too. Is there a feed from anywhere else into the rear system apart from those two?
Thanks
Mitch
hmm I'd drop around and have a look but I don't think you are local?
Its not really that complicated once you have the right pipes. One pump outlet (front) should go to the steering box, then to the resovoir, then back to the pump.
The other one (removed) goes from the rear pump outlet to the solenoids in th engine bay, then back via the wierd cooler thingy to the other resovoir outlet, then back to the pump. All that gets removed and you block off the pump and the resovoir outlet. Finally there are 2 more lines from the HICAS solenoid right to the HICAS bar at the back of the car. these come out too.
You might be able to spot the leak by having someone turn the wheel while engine is running. Good luck
  • 3 weeks later...
Hey, any news on possible removal of the HICAS computer on ECR33. I want to stick some amps in there and the extra room would be nice :P
(Already have lock bar installed)
Update on the HICAS ECU:
I now have no power steering at all.
I read in another HICAS thread something about the weight of the low speed steering being effected, but I have no power steering at ANY speed.
Not sure whether I like it or not yet.  The steering is quite heavy even in fast corners but it actually feels more direct and comunicative.  I will have to take it for a decent run through some more demanding corners and see if I can deal with it long-term.  I suppose I could just carry the ECU aroung and plug it back in when I was feeling tired/lazy :rofl:
This is fairly common and is likely a result of the controller not having a rear steering angle to input for the power steering modulation. At least in the 33 the "hardness" of the power steering is controlled according to road speed, and after the lock install will get become heavily weighted at low speed, when it should be lighter. I noticed the normal heaviness at about 80kmh.
With extra castor dialled in at the front for the track it is no longer noticeable.
Umm I should add a troubling development to my instructions....it could be co-incidence but more likely bad news.....the power steering pump on the car has got very noisy recently....
I would strongly suggest looking at PHATR32's suggestion....or saving for a 33/34 power steer pump :P
eeeeekk!!!
just as I have followed the Duncan method...hmmm
what is the PHATR32 suggestion? I couldn't find anything specific previously....
and dare I ask what a 33/34 pump costs!
(looks like the only bonus right now is that it gives easier access to the oil filter with all that crap removed!)
basicly you take the ps pump off and undo the the 4 bolts on the side of it.After you remove the cover youll see a little impeller pump thing which slides out.
Luckly the outside impeller is for the hicas and is easily removable.
Then you close the the pump up and block the outlet with a bolt.
If you dont remove the impleller and just block the hole, the pump will still be pumping the fluid, but because the fluid has nowhere to go, the pump will start to heat up and leak. maybe even wear out eventually.
i really should get my shit together and post up some pics.
steve
ok looks like I will have to do that soon before there is serious damage... Im hoping it is an easy job... does it loose much PS fluid?
and as you describe, it just slides out, and bolt the rest back up?
was expensive enough to get this far.... as here I was thinking it was a small job, but it took the guys a fair bit of time while they were fitting all the other gear....
A couple of things to add:
- As hinted at by several people in this thread, the HICAS controller in a R33 also controls the (front) power steering weighting. So disconnecting the controller results in the steering always being weighted at the 'heavy' end of the scale, whereas normally the weighting is proportional to speed - slower = lighter for easier parking.... Note that AFAIK R33's w/o HICAS have a seperate power steering only controller located in the same location as the HICAS controller.
- No-one has said this explicitly I don't think, note that the HICAS in the R32 and R33/34 is different: R32 uses hydraulic actuation whereas the R33/34 uses electric actuators to move the wheels. So comments about power steering fluid lines at the rear only apply to R32's....
In R32 gtst, if you disconnect the plug from the HICAS controller in the back the steering goes heavy as well.
I had to disconnect mine as when HICAS kicks in at around 70 km/h my rear comes out and it creeps along. I have to turn the steering wheel to 2 o'clock to keep the car going straight.
So will this bar fit the R32 gtst?
Is there any way to have the lock bar and not get the heavy steering? There must be some sort of controller to replace the HICAS one?
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
