  • Replies 147
ok edit..
everyone i think money got alittle defences cuz he doesnt know bam like we do :) so he must have through maybe he isnt jking and took the replys from everyone the wrong way.
Sauwa members seem to have ago at the youngest members for abit but they are just playing around.....
mikey.... we still pick on u :boohoo:
and we are nice to all new members, don't take things personally it's just sometimes people say or type stupid things and most of the time people will take it the wrong way because thats how it has been expressed.....
TJ, thats true.... u have enlightened me oh wise one..... lol
adrian :)
hahahahahahahahah whats all this...
word of advice to Boost Monkey - dont take everthing u read on the forums seriously.. yeah some ppl on the forums will prolly stab you but im not one of them, regardless of what people say :)
ure new here so u gotta bear with all the insults and bullying like how Mikey does, its part of the 'initiation' process but its all in fun.. most of the guys on here are good blokes just dont be alone with TJ at any time in dark places and you should be ok.. also watch out for Niz's ass.. she'll rub it on ure head given the chance :S
all rite guyss...... CHILL!!!!!! i believe 99% of the users in this forum knows that bam isnt seriouss.... so take it easy man.....
and kiddo, i will be back in perth by the end of january, from the time i reach perth, i will have about a month before i start uni... so if ya want a ride.... just drop me a message.... be verry glad to bring ya for a spin......
Dannn, shhhhshhhhhhhhhhhhhhhhhhhh!!! hahahaha
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
