22 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
SAU Crew,
Well the end of 2004 is nigh and we have partied hard this year but do we have enough left in us for one more bash.
:rave:
I know some of you are lined up to go to some partys on this night and others are either searching for somewhere to go or planning a quiet one.
So are we going to party 2gether or are you up for perhaps a recovery party on New Years Day.
Take the poll and lets work something out.
Have you got a suggestion, What's the plan?
https://www.sau.com.au/forums/topic/59378-new-years-celebrations/
  • Replies 70
count me in for the day after, i'll be working all the way through n.y.e so im definately keen for the day after, say a bbq at someones place? couple of cases (not for me) and some dead animal sound good. and we can let the public come and watch us and charge 2-bits-a-gander!!! hahaha
anyway, count me in for whatever for the day after, cant wait to see ya'll.
Still not 100% sure what im doing on NYE... recovery party definately sounds the go but.
Also, even though trivia is finished, I hope some of you are still coming for some drinks/food next Tuesday... our faithful mechanic Ed is keen to come (and he wont be working so he will actually make it this time :) ) so hopefully see some of you there then.
we went down last year and it went off down on the south beach must have been like 2 - 300 people their only downer was some tool let a couple of ufos off on soft sand :) they went flying into the croud. but yea all in all was a good night even spotted a silver r33 gtr down their
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
