I need help guys!!
I've just purchased an ER34 RB25DE NEO. I found this in the car, which no one I spoke to are able to explain to me what the heck this thing is and how to shut the light off.
Could some one tell me about this item?
Refer to the bottom right of the bigger picture for the location of the detailed picture.
http://users.tpg.com.au/topspeed/Big.JPG
http://users.tpg.com.au/topspeed/Detail.JPG
I am guessing it is a service indicator light for the car, but what is it supposed to indicated? That it was serviced on 1000km and 5000km when it was first purchased?
https://www.sau.com.au/forums/topic/59530-help-on-r34-id/
Yeah, of all the R34 I've seen that thing don't exist. I wonder if it's wise to remove them..... coz it's kinda pointless to have that on, since the car is already over the 5000km.
Perhaps not. It could be when the light comes on at 5000km, the idea is to remind the driver the car is due for an oil and filter change/service, and a reset button may then be pushed once the service is complete - thus resetting an internal counter, wired to the odometer, which will count until another 5000km is clocked up, at which time the light comes on again. I like it. It would be an accurate way to know when the car is due for a service rather than letting it go for a few 100km over. Then again I could be just making sh!t up here :) but it's definitely an aftermarket device, I've not seen one before. Kinda cool.. :)
https://www.sau.com.au/forums/topic/59530-help-on-r34-id/#findComment-1138325
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
