hey guys i was wondering whether u dont mind a stagea owner joining the club once i put my gtr running gear in :aroused:
should be ready in a month or two
ill be up for cruises etc for sure ;)
i havent had a decent road car to cruise in for ages as i never drove the vl on the street, bloody insurance costs ;)
and the vs 6 banger is a weapon that everyone just loves at cruises :throwup:
:D
Brad
https://www.sau.com.au/forums/topic/59605-does-sauwa-accept-stageas/
RB26VL - we welcome everyone as members to SAUWA. As Steve said we have WRX owners, 180sx, silvia's etc as paid members. We are a club aimed at import enthusiats... with the main focus on Skylines and definitly Nissan imports.
If you want more informatin on joining, there is a sticky thread about becoming a member. This will tell you what you have to do to join. :D
