hey guys i was wondering whether u dont mind a stagea owner joining the club once i put my gtr running gear in :aroused:
should be ready in a month or two
ill be up for cruises etc for sure ;)
i havent had a decent road car to cruise in for ages as i never drove the vl on the street, bloody insurance costs ;)
and the vs 6 banger is a weapon that everyone just loves at cruises :throwup:
:D
Brad
https://www.sau.com.au/forums/topic/59605-does-sauwa-accept-stageas/
RB26VL - we welcome everyone as members to SAUWA. As Steve said we have WRX owners, 180sx, silvia's etc as paid members. We are a club aimed at import enthusiats... with the main focus on Skylines and definitly Nissan imports.
If you want more informatin on joining, there is a sticky thread about becoming a member. This will tell you what you have to do to join. :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
