Well, Majanal's getting us organised for 19/12, but there is also a half day on 21/11. Come along and make sure you're not getting rusty.
I saw on the other thread that Roy was interested, anyone else coming along? If so, I'll get in touch with Motoconcepts.
It also looks like Steve from Disc Brakes Aus will be along, so it's a great chance to nag someone about all your brake questions:uh-huh:
  • Replies 45
Yeh for sure ill be there, fingers crossed its a cool day like today.
Need new tyres, getting Dunlop Formula Rs, pricey but everyone says they are the tyre to have.
I can get some AZENIS for $700 less (less than $1000), so i suppose the question is how much better are the Dunlops over AZENIS, and AZENIS over normal road tyres.
Hey Guys,
Just spoke to Tracey from motoconcepts regarding prices for the 19th of Dec. and I asked about how many she had booked for this day that Duncan is organising.
She ONLY has 6 cars booked at this stage.
This means that it is a really good oportunity to get along and have a day where there isn't much traffic.
This is good for young and old... I mean newbies and experienced guys.
Newbies can learn the track without constantly having to look in the rear view mirror to let faster cars past and the experienced guys can get out and have a blat with out having to flash lights at inexperienced drivers and commondoor's. Or, do as I shall be doing and get some serious sideways happening before the new set of treads goes on.
Speaking of treads, I have run azeins and will be at the track on thursday, we can chat about tyres as Duncan said.
Gotta go,
See you all thursday.
Dan.
yup i am in and a m8 witha hyundai wrx as well
should be a good laugh bloody hyundai's
i bring the camera and
i can feel some drift comming on
got the taste for it just can wait for it
sing it boys
and after the track day
i can feel some beer comming on
yea baby
:Oops: Yes, that is next Thur, 21 Nov (not 21/12!)
That makes:
1. Duncan
2. Kelly
3. Roy
4. Majanal
5. Fatz
6. Fatz's mate (!)
I'll get in touch with motoconcepts tomorrow.
I spoke to Dave this morning, and we are book for Thurs.
He did say he was only expecting about 20 cars all up, which means
1) Very little traffic, so it will be a great chance for first timers to get out there without idiots around you
2) Motoconcepts are unlikely to put on as many days unless numbers are up. It would be a shame to lose the best opportunity we have to make the most of our cars' performance.
If you've been considering a track day, this would be a great opportunity to goet out there.
Welcome, FLIP.
We'll be on the track from 1pm-5pm, you'll need to be there from around 12.30 to get organised, briefed, car emptied etc.
There's archived info on here (do a search) for what you need, but the quick summary is:
Long clothing (neck to ankle)
Full face helmet
current license (i think)
Roadworthy car (everything secured, empty cabin)
Let us know if its your first time at the track, we can help out with someone to how you around the place.
I think we'll be OK as far as notifying them, I booked for 6 this morning, but they're only expecting about 20 cars in a 40 capacity so we should be fine.
Dino, can we get a summary of trackday requirements and have it as a sticky in this forum?
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
