The apexi's aren't as loud as some of the other brands. Everyone has them, so i'd assume they're the most popular choice. I have a DRIFT filter on mine, it flows at pretty much the same rate as the apexi's and is quite a bit louder (main reason i got it was coz its a tight blue colour, goes with intercooler joints and my yellow paint) Apexi ones would probably filter dust and crap better though.. Still $30 for a DRIFT one $150 for a apexi one.. and your probably gona lose power over stock box, idk just some stuff to consider
  • Replies 300
Posted Images
Flutter sounds good on some cars not all... some cars sound absolutly f*king annoying! My friends s15 has a big ass apexi gtr intercooler i cant remember how thick the core is but i think its like 110mm? correct me if i'm wrong bout the cooler but it sounds awesome.
The quick flutter noise (like alot of skylines i've heard) and a few s15's s14's i've heard and 180's sound SHIT with the quickets tutututut you'll ever hear and then a pop after the gear change lol cos of the added richness which makes u just wana kick the owner in the teeth... besides they wanted to attention didn't they?
But flutter on standard skyline ceramic turbo = no go zone unless your looking for an excuse for a bigger turbo. :(
My 2 c.
But flutter on standard skyline ceramic turbo = no go zone unless your looking for an excuse for a bigger turbo. :P
My 2 c.
Then why didn't mine come with one from factory? (hr31 coupe)
1989 cefiro RB20DET NO BOV
1989 R32 skyline RB20DET HAS BOV
WHY OH WHY?!?!!?!?!?!?!?!?!?!
Because the cefiro uses the redtop motor with a different rocker cover, and back then they didn't come with a bov from factory.
BOV, from the factory, is only there to keep the emissions gods happy
Cefiro, as pointed out, started production earlier than R32, so different emissions rules when it was designed
That's also why the Ceffy RB20 has bigger cams than the R32 RB20
For maximum 'dose' noise, use a hardpipe between the inducer and the afm, also, the bigger the cooler, the louder it will be
Apexi pods can be bought for $98 delivered from CJ Motor (a nissansilvia.com sponsor), straight bolt on for RB20/25 and Z32 AFM.
I have seen an independant review between apexi, blitz sus, hks mushroom and K&N - apexi had best flow and much better filtering than the others. Well worth the money
Yeah Ive read that review aswell and i think it was covered on ns.com too im also a memember on ns.com ATTN gettin the filter off CJ
Heres a pod filter test if it helps anyone. i dont know if you have already seen this.
i also had the same problem with some one telling me the wastegate makes a fluttering noise. it was like talking to a god dam retard.
http://www.mkiv.com/techarticles/filters_test/2/index.html
Tom9999, that's the one, I expecially like it because it doesnt appear to have any affiliation with a particular manufacturer (or advertiser), and they test REAL power gains, as well as filtration.
Nor sure about centre lines, but bigger lift and longer duration. I saw it on a japanese website that had a comparison of nissan engines' cams over several models...
The ceffy runs bigger cams?? >_<
Just different centerlines or increased duration/lift also?
Redtop cam profiling is a bit more aggressive than silvertop. Slightly more duration and lift i think(not sure if it's exhaust side only *shrugs*). The figures are somewhere here on the forums in a thread, just can't remember how old :laugh:
aaanyway. If you want a decent fix, give me your BOV flange, i'll butcher the shit out of it with a welder, and charge you an arm and a leg for it >_< no need to worry about aluminium can bits if you are really that concerned.
Seriously. Just go to an exhaust shop, tell them you want them removed, and sell the thing/things.
I have on hand the redtop cam specs but aren't the Ceffy's silver tops?
R31's were redtops? >_<
yup, import 31's were redtops. Cefiro's are silver tops.
The red top came in two versions, NICS and later model ECCS.
This is where its interetsing, the cefiros were infact redtops with a silver coloured top. The internals, turbo, ecu are all redtop ECCS spec.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
