hmmm....ok well ive got the new ps2 and i dont want to chip it. will this mod allow me to play ntsc original games?? thats pretty much all i want from it is to play jap games and possibly dvds. does this mean that if i copy the ntsc game onto the external hdd i should be able to play it??
  • Replies 101
Yes.
All PS2's play all PS2 games NTSC/PAL/SECAM.
The question is... does your telly support NTSC ??
If not there's still hope. There are appz that patch .ISO images PAL-->NTSC & vice versa. Half the games I have are NTSC from HK and they play as per PAL, no patching.
M'kay ?
OK just checked. did back to back testing with Gran Turismo 3, HD vs DVD load times tested on all the screens available from the main menu. There was between 40-60% improvement across the menu. That's with a WD 7200RPM IDE drive (WD's do fit). the cheap one with less buffer. An 8mb buffer drive would have fared a little better. it's in my older v5/6 PS2 .
the PSTwo's USB port might be an achilles heel. USB disk drives are hella slow on my PC compared to IDE, but on the PSTwo ? Try it & see Gushiken San, at best you'll never have to swap discs again at worst they'll be slow to load.
Scratch that.
Word around the traps is:
No HDD support for PSTwo :cuss:
No HDLoader support for PSTwo. :thumbdwn:
That's the official line from $ony
$ony concocted a story George Bush would be proud of as to the lack of HDD support in the PSTwo.
The truth is PS2 always supported HDD, $ony held back while M!cro$oft was losing $$$$$ on Xbox software revenues from piracy as a direct result of HDD support. It was a commercially smart move to make the network adaptor a critical link in the chain, and to play that ace later in the game.
This is the PSX vs PS1 history repeat. And the lesson from that was: Hold on to your old hardware, it's built to a standard not a price.
I just put a 200gb seagate hard drive in my ps2, running HDAdvance 2.1. I was extremely happy with the loading times, no more load on my ps2 laser. Its nice not hearing the laser struggling to load trees and streets while driving in GTA.
MidnightGTR - check this page http://www.zophar.net/consoles/ps2.html NeoCD emu there.
Neo Geo had the best shoot em ups, hands down. Definitely get a good digital joystick for neo games. Analog response time is too slow.
ABuSD - HDLoader/HDAdvance only supports PS2 games =(
  • 2 months later...
narkeh... bring your PS2, memory card, a PS1 game and a network adapter ($30 from EB) and I'll do it for you in 5 mins... I've got a memory card editor (so you can plug memory cards into your PC and edit the files on it, same one I used a couple of years ago to get the 9000hp Mines R34 GTR in GT3). So you don't have to f**k around with all this swap magic crap.
oh you'll need a hard drive as well so I can put D1GP on it for you :cheers:
I did Danny's PS2 with a 20gb hdd out of an old PC, and I did one of my mate's PS2 using the 8gb HDD he pulled out of his Xbox :cheers: Most of the tutes out there seem to think 40gb is the lowest you can use. Bollocks to that I say.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
