I have purchased an R33 so that I could do an engine and gearbox conversion to my R32. All other parts are for sale.
Make: Nissan R33 GTST - Series 1
Colour: Maroon
**PICS AVAILABLE SOON**
mirrors - **SOLD**
driver side power window motor - **SOLD**
floor mats - **SOLD**
Parts available:
bootlid (maroon - includes Nissan badge - great condition)- $200
complete dash incl. glovebox - no ash tray - $150
instrument cluster (95,000 kms) - $150
air conditioning head unit - $100
all glass - $300
right hand side panels - $400
front seats - $200
rear seats - $85
fuel tank - $50
power window motors - $100
sunvisors - $30
roof lining - $100
door trims - $100
complete air conditioning system (excl dash vents) - $350
dash vents - $125
interior carpet - $150
roof lining - $150
standard blow off valve - $50
I honestly have no idea what most of these parts are worth, so if you are after something, then PM me with an offer. Stupid offers will be ignored.
Parts that are not available:
left hand side panels
front panels
rear bumper
shocks
exhaust
engine
gearbox
clutch and flywheel
gearbox crossmember
head unit
wheels
diff
intercooler and piping
center console
radiator
brakes
Email: [email protected]
mobile: 0412591369
Thanks,
Paul
https://www.sau.com.au/forums/topic/60948-r33-gtst-wrecking/
  • Replies 48
I am going to wait to have a closer look at the brakes before I get your hopes up... One of the wheels was smashed so it might not be worth anything...
Sunvisors have already been offered on. Please send any offers to [email protected]
Cooler is not available - as stated above.
