Here are some Pics of my great and glorious sub box
it's not 100% because the stupid jigsaw broke this afternoon. i'd hoped to have it in one piece by now
Also these are taken with my phone, my camera is in the er... shop.
It's setup for 2 x 10" plus my 400mm long Amp, which is why it's so long. the subs are within about 5mm of touching the side, which are flush against the suspension towers in the back. there is about 20mm clearance on either side of the amp from the subs. once i get some carpet to match the boot, it will look a lot better, trust me :rofl:
  • Replies 46
Well it's basically finished now. All i have to do is cover the mdf with carpet of some sort, and figure out why the stupid thing cuts out at high volume.
also, for some reason my head unit now no longer functions and i have to use the remote all the time.
anyways, tell me what you think
It doesn't sound, i had to send my head unit off to be inspected to see if they'll honour the waranty, so about 2 weeks until i have my head unit back. before i'd sent it i thought i'd fixed it up, but then it gradually got worse until it was back to where it was, which ot me sounds like either a heat problem or something gets looser as the car vibrates.
Yeah i'll get it for you tomorrow if that's alright. there are 7 pieces of MDF in all. Mine was a bit of a dodgy fit, but i'll get dimensions that will fit. A 'Prototype' as such
Get my stereo stuff installed in a few days!... wasnt gonna spend too much originally - but got a price too good to turn down... so if anyone else has been thinking about DVD and roofmount screen (for kids) then I'll post the deal I got...
Based on the pack in the summer Alpine catalogue... with the DVD head unit, 2 x IR headphones and 7 inch drop down TFT for $1999 reduced from $2799...
Told em I only had $2000 max including fitting and needed normal tuner head unit too, so the guy rang the store owner - who just happened to be sitting down with Apline distributor looking over the new Alpine stuff hitting stores soon... including an 8" screen replacing the discontinued 7"...
So he agreed to do the Pack plus a RRP $369 head unit ALL fitted for $2000!
But it got better - I said I really wanted MP3 compatability in the headunit - and he said the lowest price was for the IPOD atachable unit reduced from $699 to $499... BUT then he remembered they had them further discounted that week for $299!!
So the new price he agreed to all up including fitting is $2015, for:
- Head unit CDA-9826 (Ipod system)
- DVD player DVA-5210E
- Overhead drop-down screen (not sure on part # but its the new 8" version of the TMX-R700)
- 2 x IR headphones
RRP of $3700 + fitting (~$350) all for $2015 fitted :D :aroused:
Hi guys, fianlly got around to fitting up the stereo gear the night before the 1200 k trip. It has a Nakamichi head unit, a Soundstream 400 watt 4 channel amp and 2 pairs of MB Quart 6.5" co axials, one in each door. The amp is mounted under the driver seat at the moment, but I might move it later on.
Big improvement over standard, I ran out of time to fit the front tweaters in the A pillars. I removed the standard tweaters but was slowed down by not finding any signal at the standard wiring. This weekend I will run around with he multimeter and find the other end of them.
I now have a spare din hole, gauges maybe? The Greddy boost gauge is 60 mm, so it's too big though. So is the EGT gauge. More thinking needed and some suggestions might help????????
Sounds like a nice setup there SK. Nakamichi desks are nice and clean. And you can't go past MB Quart's. You gunna put 4 15 inch subs in the back :(
If I had a spare DIN space I'd go straight for the 3 x 52mm gauge mounts you can get. They look pretty good (look stockish) and the little thieving ba$tards can't do a smash and grab ;)
I mounted 3 x 52mm gauges in the R33 like that and I was really happy how it turned out.
J
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
