I just plugged it in, pushed the kick panel back and drove it. No problems :-)
Most other PFC problems I have heard of are word of mouth (I know someone who tried it and ....) so I wonder if its just stories being told or if they did really try it.
Mine is in a series 1 R33, so it may be a model specific thing, I dont know for sure.
  • Replies 99
both have pro's n con's
i love my auto .... seems to hold boost a lot better than a manual .... the only time i wish i had a manual is when cornering.
i like to drag - so it suits those purposes perfectly.
The power your car makes is only limited by your budget and imagination ..... not whether its auto or manual.
Have you compared the shift quality to a non PowerFC auto 33 before you had the shift kit?
Shift quality didnt change when I put the PFC in the car.
Originally my shifts were good (tight) compared to other autos I had driven (Holden, Ford, Chrysler) but after the shift kit its VERY tight. (ie it will chirp tyres between gear changes, which it would only do previously when I had crap tyres on the car) :wassup:
OK cool but have you compared your car pre PowerFC to an auto 33 running the stock (auto) ECU...
I'm just thinking out loud here so don't take offence but perhaps your car originally had a manual ECU, hence the reason you didn't notice a change in shift quality...
Every single test I've done on auto 33's with a replacement ECU has resulted in a change in shift quality...
Yeh same, its not just word of mouth, ive experienced it too. Wasnt TOO bad but it was enough.
why is yours different to everyone elses 4door?
the truth is all the gear logic and changing codes are gone, so something must have changed
what model of pfc have u got?
also did you take your car to MV with the pfc?
The PFC was in the car prior to going to MV automatics.
I have offered Sydney Kid a drive in my car next time he is in Adelaide (he didnt come to Mallalar last time) which may answer some of your questions and I believe others will value his comments and opinions.
Well firstly let me point out that i'm not taking sides here, i have owned both autos and manuals and both have their good points but i have to point out a lot of the complete crap that has been written here. It was mentioned briefly on the first page but wasn't brought up again.
I am assuming there are no engineers posting in this thread, because if there were they would tell you that some energy (and therefore power) is lost at EVERY linkage. Therefore seeing as the auto has more components and therefore more linkages it MUST make less power than a manual with similar mods.
There is no point arguing 'my auto skyline feels faster than my mates manual', you cannot argue with science. It has been proven over hundreds of years.
An auto skyline against a manual skyline with EXACTLY the same mods, the manual will win EVERY time, no arguments, assuming the manual driver can drive. Not wanting to open a can of worms, just pointing out some scientific facts. The reports i've seen estimate the drivetrain losses to be about 20-25% greater in an auto than a manual.
Cheers
:rofl:
at least this argument had facts to support it, thanks xxxx for providing a logical point of view. however in defence of auto's (remember I do drive a manual and i do think they are more fun) every person I know who races cars in drags (seriously) be it skylines or v8's or whatever uses an auto (mostly 2 speed powerglides for v8's) now all these people (plus all the ones I don't know, but see on tv) can't be wrong. now before someone jumps down my throat and says it is not the same as a normal stock auto, no maybe not but it is still an auto. the best way to determine this is do what i said before race an auto and manual. if slide is still in and has mods like mine or rwKW close to mine then I am happy to try it.
how long can a drag modified gearbox last in a daily driver? come on, surely its been tuned specifically for drag use only, with increased ability to handle short busts at high power.
as for the torque converter giving you more power... here's a few things to consider...
an official Nissan statement about the R34 says:
Nissan's new "E-flow Torque Converter" that increases power transmission efficiency to nearly the ultimate limit has also been adopted to reconcile smooth, pleasing power delivery with improved fuel economy for greater environmental friendliness.
Now from that I'd conclude that the torque converter delivers "power transmission efficiency to nearly the ultimate limit", which is that of a manual. I mean what else can you compare it to?
also... impeller, stator, and turbine in a torque converter all have energy loss, so even though the torque is being multiplied, what is being expended?
I'll try and grab the Brochures for the R33 manuals and autos and compare their power charts. Might give a better idea stock for stock.
i posted that b4 i broke my gb
runs like poo now
was hittin 187rwkw bfore and id say ive lost heaps of power
i were chirping 2nd sometimes 3rd most times but now doesnt at all
if you are going on the cruise on the 20th youll see it under good behavior
took it to an automatic fixer and he said i need an overhaul
like i said too much puttin in nuetral reving and dumping
if theres a track day coming up ill give you a drive if you want just dont crash it
http://auto.howstuffworks.com/torque-converter.htm
" In addition to the very important job of allowing your car come to a complete stop without stalling the engine, the torque converter actually gives your car more torque when you accelerate out of a stop. Modern torque converters can multiply the torque of the engine by two to three times. This effect only happens when the engine is turning much faster than the transmission. At higher speeds, the transmission catches up to the engine, eventually moving at almost the same speed. Ideally, though, the transmission would move at exactly the same speed as the engine, because this difference in speed wastes power. This is part of the reason why cars with automatic transmissions get worse gas mileage than cars with manual transmissions.
To counter this effect, some cars have a torque converter with a lockup clutch. When the two halves of the torque converter get up to speed, this clutch locks them together, eliminating the slippage and improving efficiency."
i dont know if i can wait that long, im almost at the point where i dont care anymore and will just get a pfc so i know everything will run properly :)
i hate dodgy shifts though, and its definately not good when u go to sell.
is there anyone else on sau near you that u can take for a drive to get a 2nd opinion? cos i dont understand how yours can be any different to all the other people who have tried it
runs like poo now
Who did you speak to about getting work done?
Best places ive found so far is Mark asnea at morningside and Athena Automatics at wakerly
Im going to call up MV AUTO in nsw because they are experts on skyline autos, and see what he thinks is the best way to do it; Most probably get them to send me out their shift kit etc and get somewhere here to fit it
i dont know if i can wait that long, im almost at the point where i dont care anymore and will just get a pfc so i know everything will run properly  :D
i dont understand either , im very confused .
:headspin:
Yes there are others, but no one else on these forums has the sort of reputation that Sydney Kid has (other than myself :D )
The MV Automatics I went to is here in Adelaide.
1 Stirling Rd Blackwood 5051 (08) 8370 0430
Kirra automatics they are the ones to see around (more import knowledge in bris though)
im getting my uncle to do the conversion when ive got the cash and ive lined up a manual box privately
Well my auto is about as worked as you can get. It is built to handle 800hp although i only have about half of that. It has a 4500 stall and is also daily driven. I have been driving it for two years now. The only thing that kills autos is heat. I find it easy to drive you just need to adjust your driving style, just like you would have to with a triple plate clutch. The only down side is that it uses more petrol than a manual.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
