/\ Cool. Which reminds me... obviously the standard airbox was no hurdle to achieving your 225awkw. You didn't need a pod (which I think is a defect in SA? -OT!) Just to stray OT a little how much boost are you running to achieve your incredible 225awkw with the nismo SMIC?
  • Replies 1k
Posted Images
Nah mate, A SECURED Pod filter in SA is LEGAL :-) so just one of those metal brackets and your set.... As long as its not flapping in the breeze your all good!
Running 1 bar around 16psi with highflow (pipercross) filter in standard airbox.
BTW here is an excellent tech article on intercoolers from ARE (an Australian manufacturer) - they seem to really know their stuff on air/air, air/water and dry ice intercoolers!
http://www.are.com.au/techtalk/intecoolersMR.htm
Soooo I was wondering, the old "boost tee" turbo-smart style "boost bleed" valves, which at one stage could be had for like 30 bucks (but now are all around $80-90 on ebay wtf???) weren't they just a tap with a very fine range of adjustment? Or did they have something else fancy to them?
An example of the device I'm talking about (this is a new one off ebay so I don't know if it is different to the old ones).
...what do you think, cheap & very convenient way of adjusting vent size? Or not suitable?
i think you mean this Turbotech boost controller, i had one on my old stagea.
Hey awesome thanks - no pics there but that must be the one (dunno what these original guys look like!) I would grab one but I just got a brass needle valve on ebay and also I'm not sure if the turbosmart is just a "tap"/adjustable hole... several places people mention it has a spring and ball-bearing setup of some kind... makes me think it could vary the hole as the boost pressure changes... dunno?
Rob - that's some awesome info thanks for that! Also you're only running 1psi more than me and making about 40-50kw more than me :D Glad I can stick with the standard airbox though.
  • 1 month later...
hi all,
i got a second hand Jaycar IEBC but didn't come with instructions/manual.
can anyone scan and flick me a copy?
it would be much appreciated.
cheers,
sam
I have them (in Auckland) Pm or email me your tel no or email. Did you get a hand controller with it?
[email protected]
Hi guys, great to see thsi thread has grown so much, 51 pages, that's a lot of cars with the kits. I'd like to finish Ben's IEBC, DFA and Controller but I need a copy of the instructions, I had at least 3 sets but they must have been chucked in the last big home office clean out. I have a book of course, but there are some instructions not shown in there that I need. Please if any one has a set of all 3 it would be greatly appreciated if you could scan them, email them, fax them, post them, whatever method is best for you. I'll cover the cost of whatever method you choose, just PM me for the details.
Thanks
Gary
  • 2 months later...
Try ringing Jaycar - they should send you the right ones by mail or may have them as a download. If you have no luck I can scan mine and send them but its a big file and I have to break it down into three or four emails.
they didn't really wanna know cos i bought it off autospeed
the one they had in the shop just had the extract from the performace electronics book (which i already had)
i just need the step by step instructions like i got with the hand controller
can someone help me out?
Send me an email address and i will scan and send it to you or send me a postal address and I will mail the instructions to you so that you can copy them and send them back.
[email protected]
[email protected]
sent :P
thanks again mate
need some help for fitting of peak hold adaptor - i don't fully understand "how it works" part of the Jaycar kit instruction, I'm afraid..
i have R32 RB25DE+t with 440cc low impedance injectors (ex-7MGTE) which I take it to be peak hold.
Jaycar instructions say the 0.1 ohm 5W resistor needs to be spliced in between +12V feed to an injector and +V side of the injector plug.
Does it mean that the resisor need to be fitted before injector resistor pack? After resistor pack, it will see somewhat less than +12V (resistor pack for injector: 6 ohms & injector impedance: 3 ohms), no?
So far as I know those of us with Stageas do not have "peak hold " to deal with on our S1 or S2 RB25DET or neo engines. What makes you think you have to? Have you had to fit a special resistor pack for your replacement coils? Have you test fitted your IEBC?
Bob,
I haven't tested the IEBC yet but as far as I know 7MGTE 440 injectors are peak hold low impedance, just like gtr 440cc, hence the requirement for a resistor pack.
Cheers,
Sam
so i finally got it all together, tryed to test it out by just holding the +'ve and -'ve straight onto the battery and nothing happens :D
i've taken some pics of the board so if someone could look at it for me it would be awesome
thanks, Tom
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
